Displays LCD Monitor for Gaming
Discussion in 'Hardware' started by dinjo_jo, 5 Oct 2010.
  1. dinjo_jo
    dinjo_jo What's a Dremel?
    11 Dec 2008
    Finally i'm looking to get a Full HD monitor which can help serve my purpose of gaming.
    Things which i'm looking in monitor is.
    HDMI
    DVI-D
    Audio Jack
    The only one seems to be matching is Dell ST 2410W.
    Needed the monitor for PS3/Xbox 360 gaming.Also let me know how good is the sound as i would be using it from monitor audio out usin headphones.
  2. dangerman1337
    dangerman1337 Minimodder
    2 Sep 2010
    have you looked at 120hz monitors? They seem to have VERY low input lag unless there out of your price range.
  3. Beezie
    Beezie What's a Dremel?
    1 Oct 2010
    the 120hz monitor`s are stupidly expensive and the 3d technology is still very young
  4. dinjo_jo
    11 Dec 2008
    Need something pratical and affordable, anyone used Dell ST2410 ?
  5. Rofl_Waffle
    Rofl_Waffle What's a Dremel?
    24 Mar 2010
    The ST2410 requires a sound bar which is sold separately. If you are using audio out, that is nothing more than a pass through, it would sound as good as your headphones.
    Couldn't you plug your xbox to a set of speakers instead.
    All 3D monitors have about 20ms input lag. I would call that below average. Some LCD monitors have no input lag.
  6. Siberdine
    Siberdine Safety Not Guaranteed.
    1 Aug 2010
    I use the Dell ST2410 for my desktop computer. It's a decent monitor, I got it for about £150 including the soundbar. It's not the greatest monitor, but it's pretty bright and the response time is decent. The audio out on the soundbar works fine, but getting a 3.5mm extension stereo cable might be a good idea.
    My father has a Dell 3007WFP, and when I use it I don't notice very many differences besides a higher resolution and a brighter screen.
    Anyways, I think it's a decent monitor if you're on a budget, but it would probably a better idea to save up for a better one, like a U2410, which uses an ISP panel ( Better viewing angles, etc.)
    Ask Goodbytes though, he seems to be the expert on monitors.
  7. benjamyn
    benjamyn What's a Dremel?
    11 May 2002
    I have this monitor and it's superb :)
    http://www.oyyy.co.uk/benq-g2420hd
    Use it for my laptop and my xbox 360 sometimes.
    OOS at the moment though.
    This one is slightly more, but doesn't have HDMI (though you can easily get a HDMI>DVI adaptor and use another cable for sound)
    http://www.oyyy.co.uk/benq-g2420hdbl
    But it's LED backlit so will have an even clearer, crisper, brighter picture.
  8. dinjo_jo
    11 Dec 2008
    dont want to use speakers would be connecting Hd 202 headphones directly to monitor audio out as i want to avoid the av cables.
  9. Rofl_Waffle
    24 Mar 2010
    Thats not true... If anything LED is dimmer and has a lower color spectrum. As for clarity, that really deoends on the LCD and the screen's coating.
    LED does however use less power and lower profile. Also makes the image a little colder.
  10. dinjo_jo
    11 Dec 2008
    How's the sound when using it with Monitor audio out ?
  11. Siberdine
    1 Aug 2010
    It sounds perfectly fine, like your 3.5mm headphones usually would.
