Electronics LCD monitor
Discussion in 'Modding' started by carolin, 8 May 2010.
  1. carolin
    carolin What's a Dremel?
    11 Sep 2009
    Can I use a LCD monitor power cable on a CRT monitor? I cant find the power cable for this CRT monitor I have, But I have this power cable from an LCD monitor. Would it work if I put the LCD monitor power cable in the CRT monitor? Will it fry the CRT if I try?
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    It should be all good - feel free to use the power cable :thumb:
    With just about any pc cable, if it fits, then it's in the correct hole.
    Pc's are less forgiving than girls - who usually will let you put it in the wrong hole, as long as you use some lube. You can't just put some lube on a dvi cable and plug it into a vga :grr:
    llamafur, confusis and Prometheus like this.
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Sig'd
    mvagusta and llamafur like this.
  4. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    damn you confusis! That was going to be my sig!
    However, yes you can I have used the same power cable since my CRT 6 years ago and have had other CRT monitors, LCDs, TVs and now my shiny new monitor :)
    mvagusta likes this.
