I have searched and searched, perhaps still not far enough or well enough. If I'm simply an idiot and couldn't find the link, I apologize in advance. I want to mount my 17" LCD to the mobo side of my case. I've found several mods of LCDs _inside_ the side panel, but all I personally need is for the monitor to be attached to the side. This seems simple enough, as there are 4 mounting screw holes on the back, and 2 slide holes for directly hanging from screws on the wall. I am guessing that it would be as 'simple' as putting 4 screws through the panel and into the monitor's mounting holes, but I'm unsure if the panel will support the 13lbs of weight without some kind of extra support or brace behind it. Case: Antec LANBoy Monitor: KOGi 17" LCD Any and all help would be appreciated.
