Modding LCD Not Working :( (Fixed Now With Pics)
Discussion in 'Modding' started by Mr T, 17 Feb 2002.
  1. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Yesterday i bought and wired up a 16x2 parallel LCD for a mate and checked all the wiring and everything seams fine but when i fire it up all i get is the test screen and nothing elce. Ive tried using LCDCentre and yes ive installed port95. Any suggestions of what could be wrong ? im sure the wiring is all right but ill check it all again :D. Also one thing i have noticed is that one of the chips on the rear of the LCD is getting rather hot is this normal or is something wrong ?
  2. Phrozenpenguin
    Phrozenpenguin What's a Dremel?
    11 Dec 2001
    Check, check, check wiring:) It is probably some kinda short somewhere - i had a similar problem but checking all the wiring and some resoldering sorted it :) The chips on the back shouldn't get to hot....possibly shorting again. CHeck, chek, check.....
    Charlie
  3. Mr T
    14 Nov 2001
    Will do :D
  4. Phrozenpenguin
    11 Dec 2001
    Also there is a dos program called lcdprint which can tell you if it detects an lcd - kinda useful for troubleshooting. What OS are you using and what is your parrallel port set to in the bios? ecp/epp ? Mail me if you want the prog.
    Charlie
  5. Mr T
    14 Nov 2001
    YAY its now working just an error with one of the wires :S Dahm same coloured wires :rolleyes: Oh well ill post pics soon :D
  6. Mr T
    14 Nov 2001
    Work In Progress
    A Little More Progess
    Finished Article Front
    Nice Neat Soldering ;)
    All Mounted Up Not Bad For A First Try :)
  7. Mr T
    14 Nov 2001
    And as you guys say the pics don't do it justice :D expecially the backlighting
  8. BlackFlux
    BlackFlux What's a Dremel?
    17 Jan 2002
