Modding LCD Suggestions
Discussion in 'Modding' started by [TSWN], 30 Sep 2003.
  1. [TSWN]
    [TSWN] What's a Dremel?
    30 Sep 2003
    Got it figured out!!
    Well, I got it figured out. Basically, with the Radeon, you have to go into the monitor troubleshooting portion of the video card settings, the part that shows the multipal monitor options, and click on the troubleshooting button. Make sure that you tell it to autodetect the tv. Once you do that, it should detect the screen. Now that I got it working, I can start with the mod.
  2. STellY
    STellY What's a Dremel?
    24 Aug 2003
    hey man thanks that worked... unfortunately i have a buncha dead pixels on my LCD.... thats wut i get for buyin offa ebay... :(
    anywho.... it wont let me play DVDs on it either... u havin this problem? i think there is a setting but im too tired 2 mess with it...
    anyway thanks and good luck! keep us informed
  3. [TSWN]
    30 Sep 2003
    I havent tried playing DVD's on mine, so Im not sure if it will.
    There are a few settings that i found that seem to make the monitor much easier to view. Here is what I found that seems to work.
    TV Properties:
    TV Attributes: Set at default
    Adjustments: Set the overscan button to checked
    Advanced:
    Composite Sharpness: Standard
    S-Video Sharpness: Standard
    Composite Dot Crawl: Standard
    Flicker Removal: Just a tad above center
    Format: USA
    Im not sure if this will help you or not, but its worth a try. These settings helped clear up the resolution quite a bit on my monitor.
    Good luck,
