Modding LCD wireing
Discussion in 'Modding' started by 2800@2.5ghz, 12 Jul 2005.
  1. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    just bought an LCD screen form this forum and i can't get it to work, have been using LCD smartie software.
    the LCD is parrallel and its a 2x16, but no idea what model it is.
    it also has a variable resistor for the backlight.
    when i turned it on the backlight was very dim and nothing was on the screen, i think it may be the wiring.
    i noticed on the side of the LCD there was a + and-, surely it would need this for it to functio properly, as the 5v from the molex was going to the main row of pins.
    can somebody please help me or give be a wiring diagram or any assistance what so ever.
    Thanks
  2. mingingbollock
    mingingbollock Minimodder
    15 Mar 2004
    Have you dloaded and installed port95 ? , because without it you will not get anything on your lcd, and the wiring is often as you describe .
    http://liquid-mp3.schijf.org/files/port95nt.exe
    If you still get nothing then its probably a hardware/wiring issue.
  3. 2800@2.5ghz
    23 Mar 2005
    yea, my LCD smartie software said that so i got it and installed it, can you direct me to a wiring diagram? i've looked around, but havn't found any of use???
  4. mingingbollock
    15 Mar 2004
  5. 2800@2.5ghz
    23 Mar 2005
    cheers m8
  6. 2800@2.5ghz
    23 Mar 2005
    right, i wired it up according to the 16 pinn guide, but mine only has 14 pins then a seperate 2 at the side for the backlight, fired it up, p95nt driver installed, but no backlight this time, not even dimm a dimm one :wallbash: :wallbash:
  7. ARM
    ARM Minimodder
    15 Sep 2004
    Show us your wiring diagram, maybe someone can help.
    Also there is a variable resistor used for contrast control, have you tried turning it, that maybe the reason why there's no display.
    One final thought, what is your parallel port setting in BIOS.
    ARM
  8. 2800@2.5ghz
    23 Mar 2005
  9. 2800@2.5ghz
    23 Mar 2005
    parallel settings are 378/IRQ7 and mode is SPP
  10. ARM
    ARM Minimodder
    15 Sep 2004
    Hi 2800,
    I use the wiring diagram in the LCD Smartie website: http://lcdsmartie.sourceforge.net/circuits.htm
    I haven't compared your circuit with the one above in detail, but I noticed that your circuit doesn't have pins 18 to 25 (at the parallel port) grounded. I do not know if this is an issue.
    Also LCD Smartie faq recommends that the BIOS setting is set to EPP.
    ARM
  11. 2800@2.5ghz
    23 Mar 2005
    thanks arm, i'll give it a go
  12. 2800@2.5ghz
    23 Mar 2005
    right, i did what it said and grounded them, powered the LCD up but no backlight still, but you can see the text very faint on the screen which is a start, on the diagram it mentions resistors of some kind, are these really necessary.
  13. ARM
    ARM Minimodder
    15 Sep 2004
    The two resistors of some kind that you mentioned in the diagram are variable resistors (ie resistors that can be adjusted).
    The 10K one controls the contrast, which is why I suggested adjusting it. There are some circuits that leaves this out, but I just followed the circuit and it works (I believe that some types of LCDs need the var. resistor for contrast control).
    You may want to check out the FAQ section in LCD Smartie's website; ie check your wirings again.
    ARM
  14. 2800@2.5ghz
    23 Mar 2005
    i only have the 1 resistor, maybe i'll try repositioning it
  15. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    I've wired one up according to this scheme ( http://www.icehw.net/article.php?id=104 ) with great success. Instead of using the pot, try connecting it to ground like they mentioned. If you do try using the pot, connect one side to VDD, one side to ground(VSS) and the center (wiper) pin should go to VO.
  16. 2800@2.5ghz
    23 Mar 2005
    thanks zero, the wiring was a bit of a mess anyway so i've ripped it all to bits and i'm going to start a fresh, i'll get back to you later on today. fingers crossed
  17. 2800@2.5ghz
    23 Mar 2005
    i was typing a message saying how it wasn't working but i just realised that i'm powering it from an external molex i made for the fans on my radiator WHICH DONT HAVE A 5V RAIL ARGGHHHH i'm such a ********ing ********, i'll try it on a propper molex and get back to you
  18. 2800@2.5ghz
    23 Mar 2005
    thanks for all your help dudes, LCD now working and looking saweeet.
    cheers
  19. One~Zero
    9 Sep 2004
    That's always a great thing to hear :thumb:
  20. 2800@2.5ghz
    23 Mar 2005
    :D well it passsed a bit of time didn't it, i'm planning on getting a bigger LCD or even a full colour one, so this probably wont be the last time i need your help :D
    thanks again :thumb:
