Modding LCDC Version 1 is OUT!!! W007 W007 W007!!!
Discussion in 'Modding' started by Henry, 14 Jun 2002.
  1. Henry
    Henry Matrix Orbital
    13 Jul 2001
    Hey folks, I bet you ALL read the front page but here it is again! LCDC is out and you fine Bit-Tech folks get a 15% off deal with it!!! And since we love you so much as well, we decided to make a sale to celebrate the release of this killer software...
    http://www.matrixorbital.com/products/blk202a-bittech.htm
    It's a great program with tons of features that works great!
    Like:
    Winamp (including Visual Spec)
    RSS Feeds
    Stock Quotes
    Multimedia stuff (lots of it)
    MBM5 stuff (tons)
    SETI info
    Multiple Mail accounts
    GPO and Keypad suppport (can be used to use LEDs to indicate mail, or warnings...)
    Weather!!! (Current or 4 days with rons of info)
    Hot Keys!
    And TONS of System Stuff...
    Here is the new mIRC plugin that just got finished by ikonis!!!
    http://www.plasticrandom.net/vfd/mIRLCDC.zip
    It shows:
    Weather Plugin:
    Winamp Plugin:
    SETI Plugin:
    System Plugin:
  2. lukemm
    lukemm What's a Dremel?
    5 May 2002
    so this software is freeware right?
  3. Henry
    13 Jul 2001
    Nope, it's Shareware... $17.50USD but there is a promotion right now for 15% off LCDC the Bit-Tech Folks...
  4. lukemm
    5 May 2002
    yer just found that it was 30day trial or whatever....15% off.... is that 15% off the MO LCD and software...or just 15% off the MO LCD? or 15% off LCDC.... if the last..how do i order LCD with 15% off :$
    And how does this work with LCD using a serial backpack? any ideas...
  5. Guest-16
    Guest-16 Guest
    Is there a cut down freeware version?? looks v. good though!! does it support Parallel LCDs (ie non MO).
  6. Henry
    13 Jul 2001
    No, it's made for MO Displays.. and 15% off LCDC and we have a sale on the BLks ($17.50 off :D)
  7. lukemm
    5 May 2002
    well. ive downloaded the thing and am going to try it on my lame arse maplin lcd seeing as im poor and cannot afford a MO display unless someone wants to donate the prize from the wallpaper comp :)
    ill get back to you ppl and see if anything werks 8/ although i doubt it.
  8. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
    Just to clarify, you can pick up just the MO display at the discounted price, or just LCDC at the discounted price, or both :D LCDC is shareware, and fully worth registering : its the best LCD software out there by far, and, like Henry says, tailor made for MO displays.
  9. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    It should work - I used a very early version of LCDC with a Milford Electronics LCD with serial backpack, and I believe the Maplins ones are identical. It just a matter of buggering about and creating your own defintion file for it.
    If you look on the LCDC site links page, it has links to articles where people have got it going with other displays other than MO (BGMIcros I believe).
    The only problem you'll have is that you'll probably get no support from Mat, as the software has been taylored for MO gear. Having said that Mat's a nice guy.... If you ask, he may give you some pointers.
    [EDIT] Woo Hoo! 500 posts!!! :)
  10. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    id have to say when i first started using LCDC and i didnt know how, i wrote quite a bit to mat and he was a great help....
    mat keep up the good work...brilliant software there....
  11. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Just registered.. its well worth double its cost.. Ive tried about every lcd software out there, and this blows them all away, combined.. Nice work matt..
    -scoob8000
  12. ikonis
    ikonis What's a Dremel?
    5 Feb 2002
    anyone try my plugin?
  13. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    Henry puts me out of a job :D
  14. stewe151
    stewe151 Stress Personified
    9 Mar 2002
    Speaking of MO, did you guys decide on a design from that other thread (i cant find it)
  15. lukemm
    5 May 2002
    wallpaper comp? thats revealed today i think :)
  16. LordZozma
    LordZozma What's a Dremel?
    16 Apr 2002
    I tried it Ikonis but I can't seem to get it working
  17. ChriX
    ChriX ^
    30 Aug 2001
    Yep, I tried it and works great for me :D
  18. felix the cat
    11 Jan 2002
    the mirc one???....not quite yet....
  19. LordZozma
    16 Apr 2002
    I cant seem to get it to display anything. I set the dir...put the right files into the right dirs...I dunno what I seem to be doing wrong
  20. stewe151
    9 Mar 2002
    no, where we pick the design for thr new MO LCD
