Leadtek 7800 GT and ForceWare 78.03
Discussion in 'Article Discussion' started by WilHarris, 29 Sep 2005.
  1. WilHarris
    WilHarris Just another nobody Moderator
    16 Jun 2001
  2. nemesis80
    nemesis80 What's a Dremel?
    24 Aug 2004
    wow impressive
  3. Firehed
    15 Feb 2004
    I'm so glad there's actually a site that compares a 6800GT SLI setup to the new 7-series. Your "playable" opinions are definately different than mine though, I found SC:CT 1600x1200 HDR playable on 6800GT SLI. But it's not the fast-action shoot-everyone type of game so lower framerates are more acceptable.
    Still, I'm wanting to upgrade to a 7800GT(X) more and more. I'm thinking 2GB would be more important though first, considering what I'd be coming from graphics-wise (and I do more than gaming that eats ram)
  4. TMM
    TMM Modder
    12 Jan 2004
    Any chance of getting some framerates? "playable" is a pretty broad term ;)
  5. Tim S
    Tim S OG
    8 Nov 2001
    For the most part, it is playable at 1600x1200 - there are a few parts that disagree with 1600x1200 HDR on a 6800 GT though... ;)
  6. Tim S
    Tim S OG
    8 Nov 2001
    The confusing graphs with frame rates were removed for a reason - because several forum members 'asked' for them to be removed. If you read the paragraph directly above the table, that will give you an idea of the ballpark of the frame rates - they're above that 99% of the time and +/- 1fps here and there if they're under it.
  7. OliveTheWizard
    OliveTheWizard What's a Dremel?
    20 Oct 2005
    If you could buy the Leadtek 7800GT Extreme for cheaper than the XFX 7800GT, would you?
  8. Tim S
    Tim S OG
    8 Nov 2001
    yes :)
  9. OliveTheWizard
    20 Oct 2005
    Thanks for the advice.
  10. Tim S
    Tim S OG
    8 Nov 2001
    no problem, welcome to the forums :thumb:
  11. OliveTheWizard
    20 Oct 2005
    I ended up getting the XFX anyway. The cheap leadtek was out of stock and while I could have gotten it for the same price as the XFX, I liked the software bundle of the XFX better.
Tags: Add Tags
