Scratch Build – Complete ⭐ Leaf Me Alone [Completed]
Discussion in 'Project Logs' started by InsolentGnome, 29 Apr 2019.
  1. Dr. Coin
    Dr. Coin Active Member
    13 Sep 2013
    Nice work
  2. InsolentGnome
    InsolentGnome Active Member
    14 Apr 2015
    Thanks! Never thought of them like vines but that's a great idea for another build!
    Thanks!
    That has become more of a point in my builds, at least ones that I plan on using. I'll still do crazy stuff that is impossible to change for competitions, but at home, I want to be able to swap in that new card or drive without completely tearing it down and re-modding everything. Yeah, the cables are the one kink in the plan, but I can work with that.
  3. InsolentGnome
    14 Apr 2015
    Thanks!
  4. DPete27
    DPete27 New Member
    2 Jul 2019
    Have you considered a flared channel for liquid inlays? Making the surface of the cut narrower than the valley physically prevents the inlay from coming out.
  5. Vault-Tec
    30 Aug 2015
    Very nice. Love the effect you have on the metal to make it look like jungle. Would have looked incredible under green candy. Nice work on the wood too :)
  6. InsolentGnome
    14 Apr 2015
    I thought about that when I was wanting to try 50/50 solder and I've seen a few projects that used that method for pouring metal inlays. With the epoxy, it isn't an issue since it soaks into the grain. That stuff ain't never coming out.
    Thanks! Yeah, I got the idea way back when from @mnpctech and @Mosquito. Bill did a metal table and put a candy red over it and Chris did it on his Dancing Iridescence with a candy rootbeer. They both look amazing. Finally got around to using the technique, just without the candy paint.
  7. RedWolfwere
    RedWolfwere New Member
    1 May 2011
    Would love to have this mod in my living room! ;)
    Awesome with a simple (hard worked!) design!
  8. InsolentGnome
    14 Apr 2015
    Thanks!
  9. TerHorstCustoms
    TerHorstCustoms Member
    29 Jan 2020
    This build came out awesome :) Love the custom cable job!
  10. cobalt6700
    cobalt6700 Active Member
    17 Oct 2005
    That good sir, is posh. Nice work! Love the theme, the leaf inlays and cable layout work so well together. The brushed/whispy effect on the alu parts is spot on. :thumb:
  11. InsolentGnome
    14 Apr 2015
    Thanks yall!
