Hey guys, Ok so I have a radiator which I bought add to my loop but while fitting it, I was stupid enough to use slightly long screws! Now I have four small cracks in the radiator. Does anyone know where i can get this fixed in the UK and will it be worth the repair cost or not.
You could try a car radiator repair centre. I've also read good things about JB Weld http://www.rocketstore.co.uk/shop/product.asp?cookiecheck=yes&numRecordPosition=1&P_ID=587
Thanks any ideas on how much car repair centres normally charge and if is their quality of welding good enough to trust in my rig? lol
No, sorry. I would say a tenner is a reasonable charge but bearing in mind how much they charge for car repairs it's more likely to be £200 plus parts and oil change. There's not much pressure in a rad so it should be OK after repair, just leak test it for a lot longer than normal.
