Scratch Build – In Progress Lean and Green - 15-12-14 - as complete as it's going to get
Discussion in 'Project Logs' started by Waynio, 28 Jan 2012.
  1. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Superb work mate. glad to see this coming along again. :thumb:
  2. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    good to see it all again... I had even forgotten some of the great things you did, like the fan controller knobs...
    *sits back and waits patiently for next update *
  3. Razarach
    Razarach Minimodder
    28 Jan 2009
    Awesome work. :dremel:
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
    Glad to be getting fired up with reignited passion to continue it mate. :D
    Thanks jokkos, I'm excited to be getting this back up, just want to see it in it's completed form but plenty of progress to do before that. :D
    Thanks Razarach :)
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    I slipped up on the updates so to get it right here's another 1.
    Mounting the coupling plates to the bottom plate, had to retrofit templates in place with not including mounting points in the initial design, this made fixing everything together a lot more difficult.
    Mounting support bars to the top of the coupling piece, wanted to use 3mm but was all out so went with 6mm bars.
    Back to the squirrel feet adding pegs to the front making it a good solid fit, they are also fixed in on the short ends so they don't move about.
    Optical plate mounting.
    Added rod & grub screws to bridge the gap from HDD section to motherboard section.
    Added the layers to let the mini-ITX tray slide in/out.
    HDD sliding slots to replace a HDD box I made but wasn't quite right.
    Fan perch & more sliding slots.
    HDD trays.
    Sticking the slots in place & mounting them to the panels.
    Works nice but more work will be going into it so the power & sata plugs don't have to be touched & I just slide the trays in/out of place hot plug style.
    1 more to go, then I can carry on at normal pace. :)
  6. Asouter
    Asouter --------
    18 Jan 2012
    Man on a mission Wayne, Glad you've picked this up again. Looks like you're making good progress and I like what you've done with the presentation too :clap:
  7. Attila
    Attila still thinking....
    22 Feb 2008
    Glad to see you're back into it Wayne. :thumb: Keep up the good work. There are some truly beautiful parts being made here.
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    :D Thanks Asouter, I do kinda wish I did all the cutting before starting this log though, would have been done ages ago, oh well it's rolling forward again now. :)
    Thanks Attila :) things will finally start rolling again, slowly but moving at least, no more pushing myself to breaking point & posting straight after it, that really wasn't doing me much good, getting cranky about stars lol. :blush::lol:
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Final catchup update. :rock:
    Fan perch, fan just slot on top of it for a good snug fit that has no movement but can be lifted off for maintenance.
    More work on the optical plate.
    Both pieces in place.
    Now the rods for the front corners, they all had to be ultra precise lengths & some of them needed drilling directly in the middle so I made a drilling jig to help on that, typically need a lathe for this kind of drilling, not got one so had to improvise.
    Now, the piece I love, aluminium blades on these prolimatech fans, expensive, noisier & not as good performance as akasa apache fans but I couldn't resist the aluminium fan blades, perfect for the custom fans I'm doing, full aluminium fans, yes please. :D
    First bunch of rods went in OK, the tapped ones.
    The 3mm rods though I drilled too close to the edge of the panels so 3 easy panels need remaking which will let me fine tune the design of these corner rod parts to be spot on.
    Work on the curved & bent front support piece & a fan mount for the ATX system which I did some rough but good enough milling with the drill press.
    The sharp bends I wanted made doing the curves smooth really difficult, might remake the piece from 0.5mm sheet instead of 1mm so I can do it perfect & instead of using screws to mount it, JB weld to the support piece.
    More work on the curved front & that brings this up to date.
    Few bits to remake & tweak, then I can start making new progress, already started on new bits though so should have good new progress along with fixed sections for first new progress update for a year soon. :D
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    Back to normal progress, completed a couple of new pieces for the ATX system, the expansion area cooling mount, used lexan because I had no clear acrylic.
    It's been a fair while since I designed this & realised the panel I made would have covered up anything inside too much & also cancelled the fan ducts so I could have more expansion height space if needed so I tweaked the design to properly accompany the changes & made a new one.
    Marcos_Viegas likes this.
  11. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Like the new open look panel and acrylic work. :thumb:
  12. Parge
    16 Jul 2010
    Holy. Crap.
  13. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    I seriously need to trademark this thing :hehe:
  14. Pranja
    Pranja Blackwolf
    18 Dec 2011
    :clap::clap::clap:
    Looking foward to more metal pr0n. :thumb:
  15. keenan
    keenan Minimodder
    12 Nov 2013
    My thoughts exactly!! The detail on this is immense..
  16. jokkos
    10 May 2005
    woohoo new progress... and oh my... so beautiful. I'm jealous.
    :clap:
  17. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Awesome work my favorite project on this site. Really have to finish off my project.
    Sent from my Nexus 7 using Tapatalk 4
  18. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Awesome as always Wayne! And thanks again for the Sketchup pointers :)
  19. Cheapskate
    13 May 2007
    Overbuilt to perfection.:D -Love it.
  20. bulldogjeff
    2 Mar 2010
    Good to see this one up and running again.. Looking really good Wayne
    Waynio likes this.
