Hi, im going to be doing a keyboard mod to make it glow underneath the keys using LEDs, I have drawn up a circuit diagram for it, but im not sure about the Resistor value i need. Here is the circuit: 12v | |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--| |-->|-->|-->|-->|--|--- Gnd edit : redrew it a bit better the LEDs are high brightness 120mcd 3mm LEDs, and are rated at Current 20mA and Voltage 1.7V so acording to my calculations 4x 1.7v = 6.8v 11x20mA=220mA R=V/I R= 6.8/.22 R= 30.9 so i need a resistor of about 35ohms. that all seemed ok, but then i looked at the resistor used in this exact same mod on www.heatseekerz.net and they used a much larger (about 500ohms i think it was) for a almost identical array. so my question is, what Ohms resistor do i need? cheers, jamicon
Based on your supplied parameters the resistor needed is 23.63R, the nearest real value is 22 Ohms. BTW the voltage across the resistor is not 6.8 but 12-6.8=5.2V
right the current is correct unlike i stated abv the resistor value stated by macroman is also correct but if the version at heatseekerz works then id use a 200ohm(it is on their site) and theres only 10 led strings so its 200 mA 12 v 12/0.02 = 60 ohm wich is what i would have used but it may be possible to use a 200 ohm wich would be better as it would then draw less current i dunno
Macroman, will it matter if i use a resistor a little under the needed amount? or will it still be fine and not destroy the LEDs
It won't matter being a little out either way. 22R will be fine but you could use 27R without losing too much output. I would suggest using at least a 2watt resistor.
If you read that article and then work out the current thro' the two sets of LEDs, it turns out to be about 10mA in the blue circuit and only 2.6mA for the red/green one The auther then moans that the red leds are not as bright as the blue ones. LOL
Stuff up Sorry to bother ppl again, but due to a stuff up at the electronics store, i had to get my leds elsewhere and instead got 700mcd ones. i also changed my circuit layout to 13 sets of 3 leds in series eg. |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| | |->|->|->|-| i worked it out to need a 30 Ohms resistor, and this works (ive built it, looks incredible) but i find the resistor gets very hot very fast (only a matter of seconds). its a big chunky 2watt resistor. is it ok that it is getting this hot? thanks for the help jamicon
not sure why thats happening :-/ just try a higher powered resistor . . . rapid do a 100 watt 1 that should qork
