LED Beamers
Discussion in 'Article Discussion' started by macroman, 20 Oct 2002.
  1. macroman
    macroman The One
    3 Sep 2001
  2. Mettallian
    Mettallian What's a Dremel?
    6 Sep 2002
    ha who's laughin now !
    I was just reading your article on the spot lights. I found a very similar product in the USA at a local supermarket in the auto section about 6 months ago. I changed the LED's to go with my theme and they look great! However seems how I have a black cathode I need the reactive casing. Mine are solid silver and I replaced the double sticky tape with Velcro pads so they can be adjusted up and down and side to side now. Every one thought it was stupid when I did it. I'll bet they won't scoff at you though heheh you da man! Do you know where to get those in the USA?:D
  3. Stew
    Stew Disgruntled Postal Worker
    6 Mar 2002
    Yeah my mate has had a set of those lighting up the footwells in his car (Nova) for ages.
    They work great.
    He got 'em from Halfords for about £13 ouch!
  4. silitek
    silitek What's a Dremel?
    10 Oct 2002
    Seen them around in the modified car scene for ages...
    I made my own, being the cheapskate i am, with ultrabright bl00's
    Made a reflector out of foil and cased it with some nice shrinking!!
    they are much brighter than these, only difference is i cant focus mine, wish i could.
    All in all think mine cost roughly £1.20 or so to make... :lol:
    They are lighting up my boot at the moment, never thought of using them in a PC, may just go make some now!! :D
  5. Sky Hacker
    Sky Hacker What's a Dremel?
    21 Oct 2002
    cool! and you can aim them anywhere... hmmm.. *points them at brothers eyes* that'll teach you to use my computer! muhaha
    :D :lol: :D :lol:
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    5" spot at 16" = 18 degrees. HI blue leds have a 15 degree viewing angle. So is the lens doing anything?
    :idea: Ghetto version with 99p keyring torch & crocodile clip :rock:
  7. macroman
    macroman The One
    3 Sep 2001
    The lens does make a difference, albeit small but significant. The spot is quite bright, moreso than without the lens. There is a difference between viewing angle and a focussed beam.
Tags: Add Tags
