Modding LED brightness??
Discussion in 'Modding' started by bHawk, 11 Dec 2002.
  1. bHawk
    bHawk What's a Dremel?
    5 Jan 2002
    I need to know whats a good LED brightness for my front bezel. I want to put some blue LEDs in the front for various indications, but since i sometimes like to leave my computer on over night (and its in my room) Id like the LEDs not to blind me. I saw some 300 mcd Blue LEDs at radio shack the other day, but i was wondering if thats too dim? I still want to be able to see them in the day light.
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    300Mcd is pretty dim.
    I have used those LED's from RadioShack, they will be good for replacement indicator lights. You can see them just as any other LED.
    But they won't be bright enough for case lighting, or spot lighting.
    If they are too bright at night, then MOD THEM! Add a potentiometer in line to dim them.
    Most likley they all use a common ground or +voltage that you can use one Pot to dim lots of LED's
  3. bHawk
    5 Jan 2002
    Ive already ordered 10 2000mcd blue LEDs for my case, undercase lighting, but i need the dimmer ones to go in the front bezel. Since those are gonna be on all the time, its pointless to mod in a dimmer or something. Itd be a waste of money.
    Whats the brightness on most stock LEDs that come with cases? Blue should be a bit brighter than the green ones that usually comes with cases, but i just wanna get an idea.
  4. ZapWizard
    19 Sep 2002
    Most stock LED's are around 100mcd
    Dimming those LED for the Bezel will only require a resistor.
    Very cheap and easy.
    I said variable dimmer only if you wanted to change the brightness on-the-fly.
  5. Transic
    Transic What's a Dremel?
    4 Dec 2002
