Modding LED bus
Discussion in 'Modding' started by Crazy Chinaman, 12 Feb 2002.
  1. Crazy Chinaman
    Crazy Chinaman What's a Dremel?
    12 Feb 2002
    Okay, so i'm taking a homemade baybus and using it for case lighting LEDs. The question I have is, where should i put the resistor for the LEDs? Should i just use one, inline coming straight from the PS (5V) before the bus or multiple ones right before each LED after the bus. And try to back it up with the theory, i just can't quite grasp the right answer...Thanks!
  2. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I think it depends on how many leds and rated wattage of the resistors.
  3. Crazy Chinaman
    12 Feb 2002
    6 total, all the same voltage of 3.5, possibly 7 with that. I have 4 pairs of connectors on the bus, one LED on one, two on the other three. 1/2 watt resistors with 5% tolerance...i took a freakin electricity and magnetism course...didn't quite cover this...
  4. quilb
    quilb What's a Dremel?
    12 Feb 2002
    If all the LED's are the same voltage and are connected to the one input then you only need one resistor on the input. but make sure its the right value. If ya wanted to you could use seperate resistors but why bother.
    -Quilb :rofl:
  5. Crazy Chinaman
    12 Feb 2002
