Hi, I'm going to make 4 LED case feet. If I am running them off molex and I have them running in series, what components do i need to get from maplin? Thanks, Amit
First you need to calculate the correct resistors you are going to use with the available LED's. http://linear1.org/ckts/led.php Then you need wire, resistors, LED's, and a switch (optional). Maybe some glue or whatever you are going to do to install it.
