Modding LED colour change
Discussion in 'Modding' started by cobalt6700, 19 Oct 2017.
  1. cobalt6700
    cobalt6700 Active Member
    17 Oct 2005
    Hi guys,
    Trying to get the colours right for a new build I'm doing. At the momemt
    I have a GPU with white surface mount LED's and I would like to make them blue. Was thinking either some paint or colored marker - has anyone had any success?
    Cheers :thumb:
  2. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    I used coloured acetate to change my rapid-i from white to red and green
    Had to use 2-3 layers of it. There's model paints that are translucent you can get, which was going to be my next call if the acetate hadn't worked.
    EDIT: OHP pens! Bit of old school stationary might do the trick.
  3. cobalt6700
    17 Oct 2005
    OHP pens is a good shout
