Is it best to have 6 LEDs wired in a circuit from a single molex connector, or all have individual wires from the connector all spliced together ? Im a newb and lookin' to swap out some LEDs that the front of my case .
leds well...you have to paralell connect the leds to make it work...or ypu will get powerloss if u serial connect them. how many volts are there on the leds...the best thing is to buy 5 volt leds
LEDs Right now they are serial connected, and i dont know what volt they are they came with the case. If i buy 5 volts then can i just rewire in paralell using the 5 volt molex wire with a ground? Thanks
In awnser to your question yes, if you buy 5volt LED's and wire them up to the 5 volt feed on the molex and the ground.
