Electronics LED lighting - what to buy?
Discussion in 'Modding' started by Guinevere, 9 Jan 2014.
  1. Guinevere
    Guinevere Mega Mom
    8 May 2010
    Hi
    As per another thread I'm building a new standing desk inside Ikea PAX wardrobes and am currently looking at back lighting options.
    Ebay can sell me a 5m strip of RGB 5050 LEDs with controller etc, but ideally I'll be looking at not having a continuous run of 5m. Rather I'd prefer to have some backlighting behind my displays and maybe some additional lighting in a lower shelf by my printers. Maybe even have three zones.
    So... I have a few questions from those that know about these things.
    1. Can I just cut and extend a 'generic' LED strip? Most say can be cut every 3 LEDs, do they 'usually' have solder points by the cuts?
    2. What gauge wire to extend with? Any links to spools?
    3. If I want to have two switchable 'zones' is it easier to run two independent setups with dual wall-wart PSUs, or can I run one PSU with more than one controller?
    4. If I have one controller, and can cut and extend the strips, EG have 2 x 1m runs. Can I simply add a switch between these two sections to turn the end strip off?
    PSU - Controller - LED strip - Extension wire - switch - Extension wire - LED Strip.
    5. Is there a better modular way of doing this? Pre-fabbed connections etc? Where from?
    Thanks gurus.
  2. Big Elf
    23 Apr 2009
    All the LED strips I've had can be cut and the cut mark is often indicated as a line between the 2 areas that are the solder points. Also check out the Strip connectors available which make connecting a bit easier.
    I use 16/0.2, I get my wire from Farnells but they have a minimum order level of £20 although you get free shipping. Otherwise Maplins for 10 metre lengths.
  3. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I've started using http://cpc.farnell.com/ purely as they have freepost and no minimum spend
  4. Deblow
    Deblow Minimodder
    12 Dec 2013
