Electronics Led question
Discussion in 'Modding' started by BobbyMParr, 28 Jan 2006.
  1. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    Ok so i used a the cheap 5mm led from lsdiodes.com and its soo bright when the thing blinds me when im driving ok so its mounted on the dash facing the driver so i dont forget to turn the fog lights off but its too bright
  2. mattthegamer463
    26 Nov 2004
    umm... i dont really see a question in what you just said. you want to make the LED darker? if you could figure out how to wire it so it doesnt burn out when you turn it on then you should be able to figure how to make it darker. hint: voltage/current = ?
  3. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Can't you just use a resistor to make it darker?
    (I'm no guru)
  4. THEkorean
    THEkorean 42
    10 Jun 2005
    probly the resistor or mabe you can difuse it a bit with glue gun glue that is sanded or "frosted"
  5. BobbyMParr
    18 Jun 2004
    hmm sand it i might do that then put some black model paint over it to tint it a little
  6. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    have you put the correct size risistor on it before fitting in the car?
    Use a blob of glue to hold is 3mm behind mounting hole.
  7. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    A resistor would always be better, it would prolong the life of the led.
  8. pjotero
    pjotero belgian
    2 Jan 2006
    I second the resistor
  9. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Well, you could rig up a 555 oscillator running at about 400Hz, 30% duty cycle, more street cred than just sticking a resistor in the circuit. :sigh:
    Add a light sensor to lower the brightness when it's dark and you really start cooking... :idea:
