Modding LED Question
Discussion in 'Modding' started by Mayze, 7 Mar 2002.
  1. Mayze
    Mayze PH34R my ROBO Squirrel!
    28 Jan 2002
    i think, im not sure, but is there different types of LED's? I'm going to radio shack today and i just wanted to make sure i dont get the wrong ones. i need 6 total, 3 for keyboard, 1 for power LED, 1 for Cdrom and 1 for cdrw. actually, i might replace the HD activity led also, just for fun :p
  2. linear
    linear Minimodder
    5 Oct 2001
    Well, yes.
    Most any LED will work as a drop in replacement for the things you mention. But Radio S*ack sells a bunch of items that my not, even though they're packaged like LEDs.
    Avoid the flashing ones, or the one labeled "12V" and you should be fine.
  3. DooMBlade
    DooMBlade What's a Dremel?
    6 Mar 2002
    another thing to keep in mind is the size. 5mm one may require some bezel drilling to tottaly fit in , I'd say get a 3mm , usually will fit most anything.
  4. ToM
    ToM mmmm, blud
    14 Aug 2001
    i was gonna ask just the same question, thanx for the answers!!
  5. Mayze
    28 Jan 2002
