Modding LED Specs for etch?
Discussion in 'Modding' started by Ubermich, 20 Nov 2002.
  1. Ubermich
    Ubermich He did it!
    21 Jun 2002
    Just wondering if anyone could tell me what to look for in an LED to light an etch with a 3" radius... It's for my mousetrap car, which will be run during the day, so it needs to be pretty bright.
    Also, will light from an LED carry through a bend in plexy? That is to say, could I have the LED and one end, bend the plexy twice, then etch it beyond the second bend, and have the LED light the etch? I thought I could, but figured I'd doublecheck...
    As usual, any help is greatly appreciated!
    (And the more info, the more frequent flyer points you earn!)
  2. linear
    linear Minimodder
    5 Oct 2001
    Two bends may be pushing your luck. All I can say is go for a test piece. You'll probably be better off painting your etch with something reflective, or using a silver/chrome foil instead. Indirect LED light has to be wicked to be seen in daylight or even roomlight.
