Electronics LED's, 125v?
Discussion in 'Modding' started by EternalIllusion, 4 Jul 2005.
  1. EternalIllusion
    EternalIllusion What's a Dremel?
    23 Feb 2005
    I tried searching/asking around but havent been able to find an answer for this, so here it goes.
    I have a supply voltage of 125v, and want to use that to power some leds. I know resistors would get too hot for this right? So what could i do to run those leds? Using a standalone battary is an option, but I would prefer not to do that.
    Thanks.
  2. foxx
    foxx What's a Dremel?
    5 Sep 2004
    You wont find any...at least not cheap. You could just get a wallwort that changes it to 2-4 volts for normal leds.
  3. mobius9
    mobius9 Minimodder
    4 May 2004
  4. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Look at this.
    As well as this.
    I don't recommend utilizing it without isolation and current limiting.
  5. EternalIllusion
    23 Feb 2005
    Thank you all, but I think il just go with a battery as mobius9 suggested. This is for a powerstrip mod, which will be powering my computer and maybe more at lans, so I got no mess-up room :p
