Modding LED's and 110 volt?
Discussion in 'Modding' started by Fargo_182, 18 Dec 2004.
  1. Fargo_182
    Fargo_182 What's a Dremel?
    24 Jun 2003
    What would I need to buy so I would be able to connect LED's to a plug outlet?
    some kind of inverter, resistors etc.????
    If you know would you be able to be a lil specific on the part If it would be hard to find?
    thanks in advance!
    Fargo:
  2. TMM
    TMM Modder
    12 Jan 2004
    leds typically run at about 3v~. First you need a DC plugpack/power brick/transformer, which has a low voltage output (12v DC for example) . Then you need a resistor in series with the led to further drop the current to the correct amount for your led.
    you can use Bit-tech's LED Caclulator to work out the value for a suitable resistor.
    Lets say for example, the plug pack outputs 12v DC, the led needs 3.7v forward voltage (typical for a blue led), and is rated for 40ma.
    we put those into the calculater, and..
    so you use the closest valued resister you can find being:
    :thumb:
  3. kobaj
    kobaj Banned
    4 Jul 2004
    If I'm not mistaken TMM is correct, But they do make inverters rated at 2 volts(most leds I have some across are 2) If I nead one I just go to a local radioshack I beleave they sell them for 6 bucks US.
  4. death_star
    death_star What's a Dremel?
    14 Jul 2003
    I beleive they also call them wall warts? They ususalyl have power and amp output written on them.
  5. Fargo_182
    24 Jun 2003
    thanks guys very much appreciated :rock:
  6. nick01
    nick01 What's a Dremel?
    6 Nov 2004
    For good LED control you need good current control. Every LED picks its own voltage for a given current. There are circuits to do the current regulation like: http://www.supertex.com/pdf/datasheets/CL1Datasheet.pdf
    To run off line voltage it is better to use a little transformer, for safety and because you don't loose so much power in resistors.
  7. infernis
    infernis What's a Dremel?
    5 Jan 2003
  8. TMM
    TMM Modder
    12 Jan 2004
    yeh that works aswell, but i find using an independant resistor for every led works out better then just supplying a fixed power source and running heaps of leds off that. Some Leds pull more current then others, which results in some being brighter then others (considering they are all rated for the same brightness), If you calculate the correct resister for each led, the brightness of every LED is about the same ;)
  9. zeroc3
    zeroc3 What's a Dremel?
    18 Dec 2004
    I don't know how effective an inverter is to keeping a voltage since I'm used to playing with 12V car systems. So going with that, typically I suggest using a voltage regulator, not a resistor, to pull voltage down to what you need, as car charging systems have a tendency to spike up to 18volts, not very LED friendly if you're just using resistors. So voltage spikes are something to consider, and regulators don't cost much, and you won't need any resistors, they can also handle the load of quite a few LEDs.
  10. infernis
    5 Jan 2003
    An inverter is not really useful for this situation. An inverter takes a DC signal (often unregulated, as you have experienced) and converts it into an AC signal. We want the opposite, AC to DC, or at least, AC to a usable AC voltage.
    The regulator idea is good, but you would also need a step-down transformer and rectifier to convert 110 volts AC down to a voltage range that a typical regulator can work with, and it needs to be DC. Most regulators I've seen can't run off of straight 110 volts AC.
  11. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    You still need current limiting though, voltage regulation is not enough for the reasons TMM specified - They'll all end up different brightnesses. A resistor per series string or per LED works best.
    Use some kind of transformer to lower the voltage to something safe/usable first though.
  12. zeroc3
    18 Dec 2004
    an AC adapter for something like a Sony CD player (I looked at mine, it dropped it to 4.5volts) into a regulator into a circuit of LEDs in parallel will give you equal brightness and the proper control needed to power quite a few LEDs.
    we had been talking about AC Adaptors, that's why I didn't specify that you'd need one to bring it down from 110AC to a lower DC voltage.
  13. infernis
    5 Jan 2003
    The thing is that LED brightness is a function of current, not voltage. It seems trivial, perhaps, but each LED has a slightly different I-V characteristic, so a given voltage will result in a different current sink per LED, which results in different brightnesses. What we need is a current source or transconductance source.
  14. zeroc3
    18 Dec 2004
    http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail?Ref=395616&Row=55233&Site=US
    500mA, 3.3V, min voltage is 5.3V, however, so the input voltage would need to be higher than that (9V AC adapter would work, but it's working voltage is up to 25V)
    most LEDs I've used (from www.superbrightleds.com ) were 3.3V-typ. w/ 20-30mA current, 500mA is PLENTY for quite a few LEDs, all would get the current they needed to be the same brightness.
    if you're talking about each LED being slightly different from a manufacturing standpoint, yes, I understand what you're saying, each LED will be slightly different, and I emphasize slightly, i.e., unnoticeable if the company you're getting them from has any quality control whatsoever, but yes, each LED will have slight differences in the amount of flux used, and placement of the components in the epoxy, though very very slight.
    unless you're talking about wiring in series, then yes, the LEDs would be gradually dimmer as each one acts as a resistor through the circuit, I'm talking about wiring in parallel.
  15. SteveyG
    23 Nov 2002
    :worried:
    It seems apparent that you misunderstand the V-I characteristic of a diode.
    It's not possible for the LEDs to "get the current they needed to be the same brightness" from a voltage source - You need to limit the current to each LED.
    If each LED draws the same current then only then will they all be the same brightness.
    The difference is not so slight. You may not notice too much at full brightness, but bring the duty cycle down to 10% and the difference is more than noticable. I demonstrated this a year ago with some blue Kingbrights - it's the same old story...
    :eyebrow: :eyebrow:
    First, and LED is not an ohmic conductor, it's a semiconductor. An LED cannot act as a resistor. It's basic circuit theory to know that the current anywhere along a series circuit is the same, so the LEDs would NOT be gradually dimmer "as each one acts as a resistor through the circuit". They'd all be the same brightness, since they are all drawing the same current.
