Modding LEDs and bent plexi
Discussion in 'Modding' started by nosmo, 26 May 2004.
  1. nosmo
    nosmo What's a Dremel?
    5 Oct 2003
    Sorry about the title - couldn't think how else to describe it.
    I am wondering how LEDs would shine through a piece of plexi if I bent it.
    I want to bend a piece of plexi to mount an LCD in so it sits on my desk and I can use it as a clock with LEDs shining in from the back and wondering what sort of effect it would give me.
    Hopefully my crude diagram might help visualise it.
    Code:
                        \        Viewing from here
    LEDs                    \
    shining ->  -------------
    in from          desk
    here
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    You can try to in case your diagram in code tags to try to keep the spaces.
    As for the plexi, I'm surmising if you mean directing the LED in parallel to the piece of plexi then it should depend on the internal reflection of the plexi you are aiming through as to whether it will shine throughout the plexi or be refracted.
  3. nosmo
    5 Oct 2003
    :clap: Top man - you wouldn't believe how long I was messing around trying to get that right.
    Thank you.
  4. Xen0phobiak
    Xen0phobiak SMEGHEADS!
    8 Aug 2002
    and the colour of the led's.
    The perspex could be lightly sanded with fine sandpaper, should give an even gradient of lighting going away from the led's.
  5. nosmo
    5 Oct 2003
    Would it light up the edges past the bend ie the vertical edges or would the light only show on the edges sitting on the desk ?
  6. Xen0phobiak
    8 Aug 2002
    **some** would show on the upright edgesm how much depends on the material, i cant help you there, test it on a small test peice.
  7. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    As long as the bend is a curve and not an angle(or too sharp), internal refraction *should* reflect it around the bend.
  8. vonkaar
    vonkaar What's a Dremel?
    6 Oct 2003
    The light follows the path just fine... I'll post some more 'modern' pictures in a bit, but... these are taken from my little project log (ie, The Gospel) 'The Chrome Goat'.
    Keep in mind that these panels are over 2 feet high... so... each glowing blue is only 1 LED, and... they are some of the dimmest LEDs I've used. Brighter LEDs glow sooo much better... 'more' LEDs per wall made the effect beautiful.
  9. nosmo
    5 Oct 2003
    :thumb: Great - just the result I was hoping for.
    Will go and buy plexi and LEDs now I know.
  10. Pookeyhead
    30 Jan 2004
    Yes.. it should do.
