Electronics LEDs & Bike lights (update new light)
Discussion in 'Modding' started by M_D_K, 11 Feb 2014.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Thought I would put all the things me & a guy from work have been playing with on here so that people can see what we've been upto maybe help when we're stuck or try something for them selfs as its been fun messing around with LEDs, drivers, housings and all sorts.
    Finished rear light
    Untitled by Kiteninja (Morgan Lee), on Flickr
    Gopro Style mount on the bottom as there are lots of adapters around.
    Light output is rather insane and still need to pop out to a field and see what the distance levels are but on full power you can't run it at night time its so bright.
    Now that the rear light is finished this is a quick render of the front light being machined at the moment :).
    FRONT LIGHT by Kiteninja (Morgan Lee), on Flickr
    A little bit fancier and more refined :).
    Update at the weekend when the we get the LEDs wired up to the driver to test them out.
    M.
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    Ah better than what you were showing me on facebook, fairly tidy.
  3. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Got round to taking some proper photos (well with my iphone)
    When the front light has finished I'll take some better ones still, thought I would throw it on a shet of carbon as well for added bling can't beat having sheets of carbon laying around :).
  4. Burnout21
    9 Sep 2005
    Hehe, I get to work with Carbon with Aluminium honeycomb core at the moment. I would snap a pic but it's all hush hush work..
  5. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    That should be pretty tough, I would like to play with the carbon graphine variant that is floating around at the moment.
    Use foam cored carbon board before for kiteboards.
    Update coming soon as I've just got a whole pile of bits and pieces to put together into a light shaped thing :).
  6. Shirty
    18 Apr 1982
    Ah, so this little project is what the heatsink is for. Hope it does the trick!
  7. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    The heatsink is for a Flood light for the garden, the LED going on it is 100W LED (clicky linky) its a bit too power hungry for a bike lol, the new bike light will be around 48w mind so not far off :p.
    M.
  8. Shirty
    18 Apr 1982
    I wish I knew electronics :(
  9. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    Lovely lights Morgan :)
    what are you using as a driver? and what power batteries are you using?
  10. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Various TaskLED driver boards,
    Rear light is using an lflex boost driver, 1st variant of the headlight is using an lflex also because its being powered by XPG2s similar to the XPE Reds in the rear both of these are powered by 7.2v as there slightly lower power then the XMLs.
    Aspherical headlight which I'm working on next will use 2 MTG2s (18w each) powered by a b3flex 8 a 14.4v LIPO cell.
    Last one is a XML2 U2 T6 front light which will also be a 14.4v Lipo running off a maxflex board.
    Drivers from here
    LEDs from here
  11. Nexxo
    23 Oct 2001
    The idea is to blind drivers so they can't hit you. :D
  12. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    I've been rumbled lol :p,
    (headlight and bar light are for mountain biking in the dark )
  13. M_D_K
    M_D_K Minimodder
    3 Apr 2002
  14. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Chuck this in here also :)
    new light is built :)
    Low
    High
    Need to take some pictures with my camera rather then iphone but will update when I've got some better quality ones.
    Thinking about maybe making a small batch run of say 20 units, batteries not included so to give people options of what they want to use.
    6 XPG2s in each unit, not tested but its well over 2400+lumens give or take lens loss but the LEDs are being driven at there max ampage.
    Whole light without the gopro attachment weighs 98grams.
    7.4v standard magicshine type pack will work.
