Modding LEDs on the CCFL switch.
Discussion in 'Modding' started by bilnv, 1 Jul 2003.
  1. bilnv
    bilnv What's a Dremel?
    20 Apr 2003
    I would like to hook a few LEDs onto the switch that turns on the CCFL. I drew it out below. Do you think this will work or am I way off base.
  2. malcs
    malcs oops! i put a hole in the ***** :(
    24 May 2003
    nice circuit drawing lol
  3. beta124
    beta124 What's a Dremel?
    31 Jul 2002
    that would work, they are in parallel so you are fine, because the led's are diodes it will defo make sure there is no reverse voltage - take some pictures when you are done :-D
  4. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    it will work bilnv, that's what I've did ;)
  5. LtChamp
    LtChamp What's a Dremel?
    2 Jul 2003
    i'm not an expert,
    but i'd say the resistor must be on the 5v+ wire, not the ground,
    might wanna check that out
  6. bilnv
    20 Apr 2003
    Thanks for the help.
    LtChamp wrote:
    I thought the same thing. But I was going from the diagram from System Cooling.com. The only problem was their diagram didn't have the switch. Well I think it's time to warm up the soldering gun.
  7. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Actually, in this case, it really doesn't matter which end the resistor goes, just as long as it's there to limit current and not kill the LEDs.
