Windows Left arrow key stuck down in Vista? Really random problem...
Discussion in 'Software' started by vaderag, 11 Mar 2008.
  1. vaderag
    vaderag I know what a Dremel is...
    19 Jul 2007
    Ok, i have a really strange, random problem and I was hoping somebody may be able to help.
    It's happened about 3 or 4 times in the last 2 months, but occasionally, by computer decides that the left arrow key needs to be pressed and held down indefinately until i manage to log off or shut down...
    It is NOT a keyboard issue - when it's happened i've unplugged my keyboard and tried a different one. I havent even been anywhere near the arrow key when it's happened.
    It clearly not a regular occurance, but it is happening...
    I've googled to no avail (found one other mention of it here, so i know i'm not alone, but i have no idea what's causing it!
    Anyone able to shed any light?! :waah:
  2. GoodBytes
    20 Jan 2007
    Run something as admin to get the UAC prompt. If at that dialog box, the Left key is being pressed, then it your USB port/controller, or keyboard..
    If the problem doesn't occur, it could be malware installed on your computer that does that.
  3. vaderag
    19 Jul 2007
    I can't do that, as it's not a regular thing - it just happens at wierd times - and very infrequently!
    Oh, and I run everything as admin...
  4. GoodBytes
    20 Jan 2007
  5. GoodBytes
    20 Jan 2007
    Sounds like a broken plug.
    "Oh, and I run everything as admin..."
    Support is over from me. :|
  6. vaderag
    19 Jul 2007
    What i mean is that my account is an administrator account - i'm not logged in to the Administrator account...
    And i don't think it can be a broken plug as it did it without the keyboard connected :s
  7. vaderag
    19 Jul 2007
    Anyone else able to shed any light?
  8. GoodBytes
    20 Jan 2007
    USB controller broken... try uninstalling it, in Device Manager, and restart your computer.
    If it still occurs, re-install Windows (DO NOT INSTALL YOUR PROGRAMS, just update Windows, and live with IE for some time until you can confirm that your comp is O.K.).... I am NOT saying that it is Windows fault, but I say that it could be a malware program playing tricks on you. Else, it would seam your mobo USB is broken. Disable the motherboard USB, and get a USB card.
  9. freedom810
    freedom810 Minimodder
    3 Dec 2007
    Maybe Windows being Windows? These things happen.
  10. vaderag
    19 Jul 2007
    Hasn't happened since the original post, so i'm inclined to agree with you freedom...
