Modding Left or bottom angle power cable ???
Discussion in 'Modding' started by phinix, 17 Feb 2010.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Guys, I'm sure you've seen right angle power cables.. right?
    But what I need is left or bottom angle power cable - have you seen anything like that?
    It may not exist, but it would really help me with my build to find one like that...
  2. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    When you say power cables, do you mean SATA plugs, Molex style or 24 pins ?
    EDIT: The ones between the wall and PSU?
  3. phinix
    28 Apr 2006
    Yes, I mean 230V power cable, PSU power cable, etc.
    UK version...
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
  5. phinix
    28 Apr 2006
  6. THP Dan
    THP Dan What's a Dremel?
    21 Jul 2009
    I made my own by hacking up a standard one, soldering the cable back on at a rightangle then smearing hot glue on the back. Then i added filler and paint to make it look good.
    Stands 6mm off the back of the psu ;)
  7. phinix
    28 Apr 2006
    That's cool - can you show some picture?
    I think I found something that will help me, but lets look how did you do it!:)
  8. Javerh
    5 Sep 2006
    You are one brave guy! :eeek:
  9. THP Dan
    21 Jul 2009
    Ill go find it and take a pic for you.
    Not realy, its kind of my job :thumb:
  10. cansi22
    cansi22 What's a Dremel?
    24 May 2009
