Scratch Build – In Progress Legacy of Khufu .Done on page:10.Speakers Done page:11!. 17-07-08
Discussion in 'Project Logs' started by TapperSwe, 11 Feb 2007.
which picture to use for backside fanguard
Poll closed 17 Mar 2007.
  1. pic one: scarab
    100.0%
  2. pic two: Cobra
    0 vote(s)
    0.0%
  3. pic three: crocodile/king Sobek
    0 vote(s)
    0.0%
  1. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Im not sure about that I mean if they have fans in PSU's then you should have no problems, but the electric motor should be shielded to stop that from happening due to national laws.
  2. Bas van der Werff
    Bas van der Werff What's a Dremel?
    18 Feb 2007
    And by the way, nice project you've got going i'm going to watch this one :)
  3. TapperSwe
    TapperSwe What's a Dremel?
    20 Nov 2006
    Bas van der Werff:
    Thx for the very fast reply, u got me much les concern now,it really shows that I'm no modder from the beginning he,he, i know so little about all things u can actually bay predone, that Spire FlowCooler seems to have the fans really close to the hdd to.
    Glad u like the project,next update is on Saturday :)
    Suppra55:
    thx to u 2 for fast help and thoughts regarding my issue.
  4. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Well actually, I've been using those "bushes" :p from Clas Ohlson couple o' times and I think they work very well..
    But if I could get som free, dead cd/dvd drives I'd rather use the rubber from them.
    Hey, I just realised this is my firts comment in this thread! Cant leave without telling you how great it looks now can I? It looks great :D
  5. TapperSwe
    20 Nov 2006
    JAxen:
    thx for the comment and welcome to post some more later on , by the way i saw your SoFlyXPC over at sweclockers and i really think u got a good thing going on there.
    Cheers.
  6. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    The sarcophagus is :thumb:
    The fan shouldn't be a problem.
  7. JAxen
    18 Nov 2005
    Thnx man :)
    And btw, I aint gonna call it SoFlyXPC anymore :worried:
    Guess it'll just be nameless :D but still cool ;)
  8. BlueBerryBoy
    BlueBerryBoy What's a Dremel?
    22 May 2006
    haha, snyggt. Visste inte att svenskar kunde vara så kreativa
    tanslation: lo, n1c3. 1 d1dn't know swedish people could be so creative
  9. TapperSwe
    20 Nov 2006
    Thx for the coments .
    my update is one day late because i didn't finished until today .
    So here we go ,I'm going to put 2 x 60mm fans in the front and one 80mm fan in top of the case(the 2 60mm fans moves nearly the same amounts of air as the single 80mm fan) however i didn't want to make 2 holes in the front(it would have looked strange with 2 holes in front and just one in back/top). With the angle of a pyramid the front fans wouldn't have blow the air in the right direction(u will see soon) so i came up with a angle box solution.
    Its a box /tunnel that will hold the two front fans ,there is much to gain in this because this fan holder/tunnel will not only make the air to blow in the right direction it will also reduce the sound from the fans and pick up the vibration from them .
    Here is the fans i will use in the case the big one is for a later update
    If i just installed the fans in the frontpanel they just would have been blowing the air towards the base of the case.
    Here is a paper model and A pic of how its intend to work:
    One fan on Displaycard and one is going on the other side blowing on ram and Cpu:
    Some bending and work pics :
    Cuted with multitool:
    I never cut trou the entire alu just about 70% then i use tools and hands (janking) to remove the peace ,this saves me alot of cutdisks:
    When u about to bend more complex things u must think trou before u start otherwise u will run into alot of trubels here is some bending pics:
    Done now i must drill al the screwhole +sand and contersink them:
    Screwholes and fan holes done:
    I cuted down 8 screws to make a better fit:
    And with fans mounted:
  10. TapperSwe
    20 Nov 2006
    This is Hairy demon AkA Gizmo who i called in to help me out today (he dosent look to happy about it):
    I used a 5 mm thick ruber to put between the case and fantunel:
    I took a net from an old speaker to use as dustfilter:
    This is the fan hole in the frontpanel (the box will naturally be mounted on the other side):
    Like this:
    from frontside on net:
    Next update is going to be the fanguard for the front fans naturally i dont need one because the fans are not even close to the front but it will look much nicer then with just a black net.
    Comments thougts or questions is welcome...
  11. TapperSwe
    20 Nov 2006
    changed
  12. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    A dremel is a great tool for some things but wouldn't that have been easier with a jigsaw?
    This is an interesting project and you're putting a nice level of detail into your project logs :thumb:
  13. kylelnsn
    kylelnsn What's a Dremel?
    19 Dec 2006
    yeh very nice mod ! keep up the extremly good work, got my eye on this one! oww and i loce the bending pictures backround! KITCHEN SINK love it nice one!
  14. TapperSwe
    20 Nov 2006
    Tyinsar:
    Thx for coment.
    Yes on bigger pieces the jigsaw is better ,i used it in the begining to cut out al the big parts like base sides and doors,but on smaller/medium size bits i prefer the dremmel/multitool because u dont have to put tape on the alu to prevent scratches u dont have to drill holes for every turn u going to make so in the end i dont know if its faster to use the jigsaw on medium/smaler pieces, I also feel that i got beter control with the multitool over the jigsaw but thats more of an personal thing.
    kylelnsn:
    Thx and yes i do all my work on balcony/kitchen.
  15. JAxen
    18 Nov 2005
    Bandwidht exceed @ photobucket D:
  16. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    image station is a good service, its what i use. i cant wait to see what you posted!
  17. TapperSwe
    20 Nov 2006
    ok I have exed my limit at photobucket so i must come up with something, i tryed to remove pics but i cant post anyway ...
  18. guysy1110
    guysy1110 What's a Dremel?
    15 Feb 2007
    Can you not just create another photobucket account ?
  19. TapperSwe
    20 Nov 2006
    Thx i will but not tonight have to wait untill tomorow.
  20. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    You could always create a googlepages account (or several of them).
