Windows LEGIT OS software for pc repair
Discussion in 'Software' started by gar, 10 Feb 2012.
  1. gar
    gar Minimodder
    15 Sep 2004
    I have started my pc repair business, but am struggling to find a way to reinstall OS on laptops and pc's. They all have the licence, so thats fine, but how do I get the software. XP vista win7!?! No idea were to begin tried google, but that whole torrenting thing looks dodgy to say the least.
    Any pointers would be greatly appreciated!
  2. David
    7 Apr 2009
    Windows 7 ISOs can be downloaded legally from Digital River Content. Obviously, you still need to purchase a key.
    clicky
    I don't think they still list the XP/Vista ISOs though.
    adidan likes this.
  3. gar
    gar Minimodder
    15 Sep 2004
    Cheers man. Got that installed on another customers laptop. Seems impossible to do things legit these days. I don't know what other pc repair guys do. ::(
  4. Yeoo
    Yeoo Minimodder
    1 Sep 2011
    Well i know one who installs a pirated windows 7.. but i dunno what the legit guys do.Can you use a OEM s/n with a retail disc? or is it different? I recon some Ebay work maybe needed to collect some disks
  5. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    what about Windows XP?? is there any legit ones?? I have the key but no disc.. since i lost the stupid disc when i moved too many times.. :(
  6. Unicorn
    25 Jul 2006
    Saftware? I think you mean Software. We get copies of operating systems the obvious way - we buy them or download keyless ISOs, then just use the customer's license key for the reinstall.
    adidan likes this.
  7. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    if your running a business, i would insist that if someone comes with a broken laptop / pc that they supply the original disks along with it, otherwise the cost significantly increases
    not just for a working copy of windows but for the driver hunt that is generally required also
  8. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    Have you looked into a technet subscription?
  9. short1uk
    short1uk Minimodder
    20 Sep 2011
    It is difficult it's taken me sometime to get every disc I need. Luckily I have a good friend who started his business few years before me.
    You need
    XP home SP3
    Windows XP media centre edition
    Vista x86 & x64 -,sp1 and 2 as well
    Windows 7 Oem x86 & x64
    Also it's handy to have all the dell discs too
    Driver Genious is very good for missing drivers
    Jelly bean is good to extract license keys got installed software
  10. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Where are you in Canada? I may be able to help.
  11. Unicorn
    25 Jul 2006
    He lives in Northern Ireland. +1 for Jelly Bean, I'd be lost without it! I generally don't insist on the customer providing the necessary software because we have most of it on the server right here, even drivers etc. It's only a PITA for the first hundred or so PCs that you repair, then you'll find yourself re-using driver installers etc on a regular basis.
  12. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    technically, you should use the inbuilt recovery system, if it is no good, you should contact the oem who built the machine for recovery disks.
    using normal oem disks, is technically against the licensing agreement
  13. Unicorn
    25 Jul 2006
    Most desktop PCs don't have recovery partitions Rich.
  14. RichCreedy
    24 Apr 2009
    mass produced ones do, or they provide the facility to create recovery kits
    if they dont have either option, then the oem must provide the oem disks, a small firm producing their own brands, even if they provide the recovery partition, must provide the oem disks supplied with the license.
    vista machines were supplied with an anytime upgrade disk, which could be used to re-install windows if needed
    JBond likes this.
  15. gar
    gar Minimodder
    15 Sep 2004
    Thanks guys, although I am suprised that this seems a grey are as it is illegal to download most ISO files from the internet.
    I contacted Fujitsu Siemens for the laptop I'm currently repairing and they were happy to send the OEM disc out for vista, but there are so many builds and versions, it's unbelievable!
  16. David
    7 Apr 2009
    You're lucky - most OEMs charge for replacement discs. HP are criminally expensive.
    JBond likes this.
  17. faugusztin
    11 Aug 2008
    For laptops, every user is supposed to create their own recovery disks, or order them from a service the manufacturer set up. For example, for Toshiba in EU, you are supposed to order recovery disk from https://backupmedia.toshiba.eu/ after entering the serial number of your laptop and then paying the 30€ handling fee :). Same applies pretty much to any laptop manufacturer, with fees ranging mostly from 19 to 30 euros.
    It is pretty much a fee for being stupid and not creating your own recovery disks.
  18. gar
    gar Minimodder
    15 Sep 2004
    Yea, sorry I do live in Northern Ireland. If it's possible in anyway to pint me in the correct dirction that would be greatly appreciated. I don't wish to get into the whole torrenting business, I don't think it's wise somehow.
  19. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Indeed. Hard to tell whether anything has been added or otherwise tainted the iso.
  20. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    filestube.com- knock yourself out.
    It is completely legal to download an ISO of the OS software- you are only paying for the license key which the owner of the PC/ Laptop will already have unless they have lost or damaged the little holographic sticker / CD case with it on.
    I would suggest making 'master copies' of all the various versions, or a single disc with all the versions on which you can then select the one you want during set up ( home basic, pro, ultimate etc of XP, Vista & 7 ). I had to download a copy of the XP home basic ISO a while back for my virtual machine- completely clean an untainted- you can always test these ISO's yourself as a virtual machine in a sandbox, to make certain nothing nasty has been hidden in there.
