Notebooks Lenovo G570 Laptop £557.68 from ebuyer
Discussion in 'Hardware' started by freshsandwiches, 30 Jun 2011.
  1. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    http://www.ebuyer.com/product/265605
    A regular email from ebuyer contained this today and it caught my eye. It seems to have a good spec at a fairly reasonable price and I'm wondering what bit-tech makes of it.
  2. adam_bagpuss
    24 Apr 2009
    i3 is entry level so seems expensive CPU wise
    stupid RAM configuration as bloody usual from retailers
    low end descrete GPU is nothing special
    id say should be cheaper
  3. LennyRhys
    LennyRhys Oink!
    16 May 2011
    No it's not, lol. Entry level would be a single core CPU like a Celeron or Pentium. Laptops with Intel's "Core" series cost a lot more because they have the newest architecture - we found this out when buying a new lappy for my wife, and in the end settled for AMD because they were the only reasonably priced units.
  4. adam_bagpuss
    24 Apr 2009
    i3 is intels new entry level CPUs
    they arent bad or the cheapest but they ARE entry level for the new range
    same laptop without the GPU
    http://www.ebuyer.com/product/265604
    contains an i5-2410m which is considerably faster
  5. David
    7 Apr 2009
    You can still buy new single core laptops? :jawdrop:
    The screen is definitely budget. That's a sh!tty resolution these days.
  6. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
  7. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I know that it is entry level for the range of CPUs, but OP is talking about buying a laptop, not a CPU. As far as laptops go, Core i3 is midmarket and is certainly not what you would find in an "entry level" laptop, hence why I don't think this is expensive for what it is.
  8. smc8788
    smc8788 Multimodder
    23 Apr 2009
    Unfortunately, pretty much the standard for 15" laptops under ~£700 these days.
  9. freshsandwiches
    9 Aug 2009
    Thanks for the replies. I am on a budget and thought this might be a good compromise plus it's the first laptop I've seen at this budget that has a blu ray drive and a GPU. I would like the option of playing games (albeit on low settings). Plus I don't want a screen any larger than 15.6".
    If anyone has other suggestions let me know. I have until August to take the plunge. I'm a teacher and need a new one for school :p
  10. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    They think that because it has an LED backlight all is good. :blah:
  11. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    WHO THE HELL NEEDS 6GB OF RAM IN A LAPTOP???!!!!
    edit: I am just saying this after a friend has upgraded her laptop before she bought it for an extra £150, from 4gb to 6gb of ram.
  12. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Just for the record, Pentiums are entry level 1155s, not i3.
  13. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    In the desktop segment yes, but currently there are no 1155 Pentiums in the laptop segment (unless they have been introduced very recently - the only Pentiums that I know about are the Arrandale models).
    Technically speaking the Pentium models are just i3's without HT and lower clocks anyway, the difference is relatively minimal.
    In the budget sector, laptops with i3 CPU's can be bought relatively cheaply, I don't really see any point looking lower again.
    To the OP:
    For light gaming try to find a laptop with at least a Nvidia GT420 (NOT a GT520) or AMD HD5650m. Coupled with a decent CPU they will easily manage medium settings at 1366x768 in most modern games. Anything lower than these GPUs and you will really have to make quality sacrifices to get the game to run let alone be playable.
  14. bladecs_04
    bladecs_04 What's a Dremel?
    5 Jan 2011
    i think the reason the laptop is so expensive is its one of the few with a blu ray player.
  15. javaman
    javaman May irritate Eyes
    10 May 2009
    http://www.ebuyer.com/product/268391 Out of stock now but picked one up last week. lacks a dedicated GPU but HD3000 is decent enough and more importantly quick sync. For the price THAT is a freaking awesome deal.
  16. adam_bagpuss
    24 Apr 2009
    Thats a much better deal javaman
    shame its an acer though !
  17. javaman
    10 May 2009
    I thought that too when I ordered it. It was down to that or a last gen i3 Asus and the specs won but tbh the build quality is very good, Possibly better than my GF's Lenovo. The screen quality is impressive and the keyboard was fairly comfortable. The touch pad might be a tad flaky at times but scrolling on it is responsive compared to any other laptop I've tried. Its not much but Compared any bull crap HP, Compaq, dell (solid but look and feel like crap) or advent, Acer are easily premium!
    I've an aspire one netbook too, picked up from amazon for £250 with the extended battery 2 years ago and the keyboard and screen where miles better than anything else >£400. Apart from fan sounding like its grinding the last few months its been pretty sweet.
    Ill picture it now and upload if people wanna see and OP doesn't mind.
