News Lenovo hits the spot with first 22" WUXGA display
Discussion in 'Article Discussion' started by Da Dego, 18 Sep 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. phat-ant
    phat-ant What's a Dremel?
    23 Feb 2006
    a good step in the right direction. now all we need is more crazy res monitors like the old IBM T221 22.2" with a whooping 3840x2400 res.
  3. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    looks awesome
  4. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Stereotypically boring Lenovo design as usual. :/
  5. eek
    eek CAMRA ***.
    23 Jan 2002
    Seems pretty expensive, should be able to pick up a 24" with the same resolution for a similar price!!
  6. bloodcar
    bloodcar Minimodder
    1 Sep 2002
    Yeah, but the 22" will look a lot sharper then the 24" at the same resolution. I've been wanting to pick up an LCD for some time now (yesh, I still use a CRT when I'm not on my laptop) and I might just give this Lenovo a go.
  7. dfrangu
    dfrangu What's a Dremel?
    18 Sep 2007
  8. JADS
    JADS Et arma et verba vulnerant
    27 Mar 2001
    Still waiting for the 30" 3840x2400 display with a plethora of outputs and a quantum leap in colour reproduction and black levels :geek:
  9. Guest-23315
    Guest-23315 Guest
    Don't care how good it is, it looks aweful.
  10. gpw111
    gpw111 What's a Dremel?
    17 Apr 2005
    i think you'll be waiting quite some time - and don't u mean inputs anyway?
  11. crazybob
    crazybob Voice of Reason
    21 Oct 2004
    Why's everyone getting all excited about the style? It's a monitor - a bunch of plastic bits you'll never look at which support a big, expensive glass pane you'll look at a lot. Both of my monitors right now look equally bland and I can't say that it has ever caused me any significant trauma.
  12. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    I see the story has now been updated. The Lenovo is US$550 so should come in under £400 (still cheaper than plenty of 24" of the same resolution). For reference, I found the EIZO CG221 for £2,800 (over US$5,000!). So this ThinkVision is still big news because it's the first consumer-level WUXGA 22"
  13. JADS
    27 Mar 2001
    Well a 30" WQUXGA display might not be too far off and Samsung has been experimenting with Dolby's IMLED technology so the two may meet in the not too distant future :)
    I definitely mean outputs, DVI, Displayport, HDMI, Component, etc...
  14. Jipa
    5 Feb 2004
    Ummh.. Why the hell should a monitor have outputs?
    And this is great news! Screw 22"-ers with 1680x1050-resolution and TN-panels!
  15. xion
    xion Minimodder
    23 Aug 2006
  16. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    I'd buy it for $550. I wouldn't buy it for £550, which is of course what it'll cost here...
    P
  17. wyx087
    15 Aug 2007
    hum..... does this mean my shiny new 1680x1050 22inch will drop in price?
    ah, i'm still not used to getting ripped off
  18. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    Hmm nothing compared to the monitors used by the NHS for imagaing there like 5000x7000 (can cost LOTS!).
  19. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
  20. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    @ kipman and DXR: Maybe because the brightside screen is so expensive only the elite would buy a 20.000 pounds screen.
    bot:
    Although i like the idea of a 1980 resolution on 22". I allready have a hard time reading words on my 1650 reso 20" widescreen. I rather have a cheap 26" or higher with 1980 res. with makes it more usefull as both monitor and moviescreen.
Tags: Add Tags
