News Lenovo responds to laptop reliability study
Discussion in 'Article Discussion' started by CardJoe, 20 Nov 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I wouldn't be surprised to hear that the figures for all of the manufacturers is lower than claimed.
  3. B3CK
    B3CK Minimodder
    14 Jun 2004
    I didn't realize that the previous article was from a company that sells 3rd party warranties. That does show the effect of some propaganda marketing trying to gain some sales; but I do see how the timing of that article can effect holiday sales for the initial purchase this year.
  4. leslie
    leslie Just me!
    19 May 2009
    There were a few things on there I found odd, much of which I chalked up to it being an aftermarket warranty.
    As for the rates being lower, they more than likely are. This isn't a company you get insurance from at checkout, you have to search it out and you have to wonder, how many only did so after having a problem.
  5. pullmyfoot
    pullmyfoot superbacon
    1 Oct 2008
    Personally the number of computer parts (I build a lot of computers) I have had to RMA for legitimate reasons is like one in a million
  6. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    This is just the usual thing that you can make statistics say whatever you want. Were their figures just from those people who has stumped out for extra warranty with the company? If so that more says something about how they market their service, which, I imagine, is something along the lines of "cover all eventualities" so will be taken up on the most part by people who do things which may risk damage to their laptop etc.
  7. coolius
    coolius What's a Dremel?
    29 Jul 2007
    My Lenovo laptop is still going strong after 5 years! Pentium M Cheesecake!
  8. Guest-23315
    Guest-23315 Guest
    Uh oh. Time to lower the level of this thread.
  9. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    All the (newer) work laptops are Lenovo's and haven't heard anyone having failures etc of laptops. They tend to be a bit slower/clunkier than the older IBM's but they're still rock solid in terms of reliability.
  10. somidiot
    somidiot Minimodder
    18 Aug 2009
    I tend to agree with what the Lenovo guy said especially with the number of units they sell, although they're not purest enough to actually release their own internal numbers. Now that's something I'd like to see.
  11. leexgx
    leexgx CPC hang out zone (i Fix pcs i do )
    28 Jun 2006
    Lenovo systems i have seen generally are solid and just keep on going (baring you dropping them or loading virus onto them)
    more acer system lately have been getting to easy to brake, why do laptop makers have to make the power socket out of paper they are Really Skimping on securing the socket and results in it been broken, putting it on the side resolves that problem mostly
  12. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    There is a huge difference between failure rates on computers used in different environments.
    If those numbers are based on computes sold to the private market I could believe it to some extent (I could, but i won't). The problem that this segment is where most failures occur. Rough use and poor build quality will make things break. Most consumer level computers aren't made to withstand daily traveling and moving about.
    Computers made for the business market are built very differently. Better materials, stronger construction and they don't push performance to the limit. Unfortunately this give bad specs, boring looks at a higher cost compared to the oh-so-shiny-but-cheap laptops.
    Consumers want good looks, but don't want to pay for it. It's those who pay the least that expect the most from a computer, for some reason...
    And then there is the test period. 3 years is one generation in the computer market. That means that if a manufacturer had a bad series of parts it will be very significant on this test. HP had the DV6000 and DV9000 series that failed all the time due to a fault in the construction of the motherboard. IBM also had a line of bad hard drives a few years back. (IBM Deathstar anyone?)
    I have also dealt with companies that sell 3rd party warranties/insurances. They are all a bunch of scammers IMO...
  13. squaretradevince
    squaretradevince What's a Dremel?
    21 Nov 2009
  14. Psytek
    Psytek What's a Dremel?
    23 Dec 2008
    What criteria were they using to define 'reliability' ?
    It is extremely rare to get a hardware fault within the first 3 years of purchasing a new laptop, I imagine a lot of reliability issues relate to the user's treatment of the laptop, and also, windows...
  15. cybergenics
    cybergenics What's a Dremel?
    27 Jun 2009
    If you go on the Apple website, they are running some of their 'Get a Mac' adverts that keep mentioning that Mac's are the most reliable computers according to some survey or other. Who's survey are we to believe. Also, I noticed the Hyundai Getz, Chevrolet (Daewoo) Matiz and the Kia Rio were pretty damn reliable according to surveys....but will I be getting one ? Will I **** !
  16. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Maybe this company has a large percentage of lenovos on their warranty ledger and needed an excuse to raise premiums?
  17. djellison
    djellison What's a Dremel?
    7 Jan 2007
    We have a stock of about 24 thinkpads at work. They sit in laptop bags for 90% of their lives. They then get DHL'd to exam venues for two days of computer based exams. 1 in 6 has died after 3 yrs. Not all the same failures either. Screens, HDDs, Keyboards. It's a statistically large enough sample that personally, I wouldn't touch one.
  18. leexgx
    28 Jun 2006
    monitor is Very likey user fault the amout amout of times i have seen an customer pick up the laptop using the screen as an handle and crack it or they droped it (HDD death is droping the laptop when its on or sudden low 1-3cm drops when on) keyboards apart from water damage how was each one broken
    DHL not allways carefull with items
  19. djellison
    7 Jan 2007
    The HP's that have been through a same process - a statistically significant number also - have had NO failures.
  20. alecamused
    alecamused Minimodder
    22 Apr 2008
    I can relate to the original study. At work we have lots (12-15) of Dell notebooks, 2 Samsung, 4 Apple, 3 Asus and 4 Lenovos. 3 of these notebooks are constantly causing trouble and all 3 are Lenovos. Silly stuff like random noise from speakers (and headphones), keyboard not discovered (3/10 times it's turned on), half display stays black now and then. And the really annoying part - we had them rma'd and they came back as "fixed" and the same issues appeared again within the first hour of testing.
    We had IBMs before and they where marvelous (and so was the support back then).
Tags: Add Tags
