Hi guys, my daughters lenovo s145 screen is dark, can bearly see the lenovo logo on the screen at boot up, ive tried it with another screen and same thing happens, any ideas, thanks
Have you tried Windows Key + Ctrl + Shift + B (refresh display connections)? If it's happening on plugged in screen it doesn't soundl like a backlight failure.
Yes ive tried connecting to a tv but no picture onscreen, ive tried the windows key+ctrl+shift+B no joy, thanks matey
Is that with another replacement internal screen or an external one/TV that it seems to have the same dark logo? A lot of Lenovo laptops have a fuse on the motherboard for the backlight which can blow. Once it's gone, the backlight never works again, even on replacement screens. If this is the case, the only options are to replace the tiny surface mount fuse, or bridge it with solder and hope for the best.
Cheers buddy, i connected it to a tv, nothing was coming on screen at all...i see lenovo on the laptop screen but i dont see that on the tv screen, ill just use it for spares matey, thanks again
