Scratch Build – In Progress Level Eleven
Discussion in 'Project Logs' started by slipperyskip, 1 Mar 2010.
  1. voigts
    voigts What's a Dremel?
    26 Apr 2006
    I hate people who can just whip stuff out of their heads like this and make it work. :sigh:
    I'm far too plans/design dependent. If I don't design a case first before building, I'll end up with nothing but a mess.
  2. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Great comments guys! Thanks. I'm currently off-planet but here are a few photos.
  3. stonedsurd
    11 Mar 2009
    What can I say?
    The size is freaking me out :p
  4. skreenname
    skreenname SFF Forever
    11 Jun 2009
    That's what she said...?
    -Shot-
    And damnit, now I want to make a little PicoITX computer for downloading while pulling a minuscule amount of power.
  5. enori
    enori Where is the 'any' key?
    28 Feb 2010
    wow... it looks amazing :jawdrop:
  6. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks :thumb:
    The twin boxes measure 32.3 cubic inches each and the support box measures 35 cubic inches. I'm working at one-third scale of the original.
    Velcro and rubber bands holding it together. There is plenty of opportunity to move stuff around. It is freestanding in this photo. Smaller boxes for the two empty quadrants are being imagined. The top/back box will have aux jacks and a cooling fan. The front/lower quadrant will be pure form over function. Something tasty I hope. :hehe:
  7. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Whats the retail pricing for the mobo? Id love a tiny media Pc to replace the bulky one i have now, but the only place i can find them for sale is HERE and they want a whopping £263.26 or $402!!
    I know small form factors command a bit of a price increase but really that much?
  8. ringo
    ringo What's a Dremel?
    14 Jun 2008
    I like your very smal case, and the basic work you do. I will follow to your project, to see the result
  9. nlancaster
    nlancaster Minimodder
    21 Dec 2009
    http://mini-itx.com/store/ - good in the UK, but you can order from them in the US
    http://www.itxdepot.com - good for US mini-ITX and pico-itx boards start around $225
    good spot for mini-itx, and pico-itx, Pico ITX board there at £139.00, but it does lack the HDMI
    http://mini-itx.com/store/?c=43 - this kit comes with a tiny PSU, case, and a huge amount of extra cables for IO, and is only £189.00
  10. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Cut the I/O shield to size.
    Cut out the I/O shield box opening.
    Hand-turned a hole saw to start opening the vent port.
    Used my four-faced hand rasp to finish opening the vent.
    Pause for a pose.
    Attached the I/O shield.
    Checked the fit.
    Showing the gaps around the shield area that will be dressed up.
    Cut out and glued in some filler pieces.
    The filler pieces tighten everything up.
    Cut out a few pieces to dress up the lower section. These pieces will be glued to the mounting board and not to the box. This will allow me to remove the box while the computer is operating and cables are plugged in.
    Result of efforts. Thanks for looking.
  11. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
    Looking better and better every day. I'm still going to find some use for a PC like this in my car... I do want to get a few other things taken care of first though. :)
  12. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks. I think this particular Pico-ITX model was designed to be used in a set-top box. The HDMI and 1080p would be wasted in a car unless you happen to drive an RV. :hehe:
    I cut my vent screen gaskets out of 1/32" basswood. The interior cut is precision but the outer cut was loosely hand cut.
    Stainless steel screen is cut to size.
    The gasket is slightly thicker than the screen so I can layer another slightly smaller windowed piece of wood across the assembly. I'll set this aside for now.
    Cut some wood to use as a mounting system for the SSD.
    The two smaller pieces are glued together.
    This creates a "sliding bracket" kind of thing to insert into the aluminum angle.
    The center section is slightly raised so that I can glue this bracket to another piece.
    Cut some 1/2" square stock to use as spacers for the support box.
    Dry fit.
    I've gotta get a "glue drying" photo in here somewhere.
    Thanks for looking.
    BTW, this project is more of a tribute to the Edelweiss case mod by Pius Giger than to the Thermaltake Level 10. IMHO, BMW and Thermaltake just ripped off a fellow case modder's original idea. I have been wanting to do an Edelweiss-inspired mod since I saw the original in 2006. I'm not a big fan of the Level 10 mainly because I believe the basic design is more suited for a smaller PC. :hehe:
  13. BigBazz
    BigBazz What's a Dremel?
    14 Feb 2010
    I remember checking out that case on mdpc the design was pretty unique. This is shaping up very nicely :)
  14. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    What kinda OS are you going to run on this slick looking machine? I'm assuming a flavor of linux.
    BTW great progress on the build
  15. swaggahurtz
    swaggahurtz 2 c not what is but what can be....
    24 Feb 2010
    Ah a true master of his craft..... :) Your work is awesome man.
  16. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    3 boxes of Orden ?
  17. slipperyskip
    slipperyskip Member
    26 Oct 2003
    Thanks. I call the Edelweiss and Level 10 "inside-out" computers. Hang the components on the outside of the case and hide the wires inside. Make the "case" smaller but still structurally sound and there you have it. The Level 10 has only wires inside. Edelweiss has the PSU still inside the case and mine will have an optical drive.
    Thank you. Probably 64-bit Win 7.
    Thanks for that. I appreciate it.
    Huh? Boxes of Oranges? :D
    Mark the window size on a piece of cherry veneer.
    Cut the windows out.
    Gather the components.
    First, the gaskets get glued on.
    The stainless steel screens are layed in loosely.
    The cherry windows get glued over the top and trimmed up after drying.
    Thanks for looking.
  18. voigts
    26 Apr 2006
    Your detail work is excellent. That IO plate is dead on as well as the other box cuts.
    Where do you get wood that thin i.e. 1/32", etc. ?
  19. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    I don't know why there aren't any stars on this thread, every time I see a slipperskip log I know I'm in for high quality and inspiration.
    Have my stars.
  20. Evenge
    Evenge Minimodder
    16 Sep 2006
    +1
    Those mesh windows are cool! I assume you are not going to put any extra fans behind them?
