Modding lexan/polycarbonate thickness???
Discussion in 'Modding' started by thecrownles, 19 Mar 2004.
  1. thecrownles
    thecrownles What's a Relix?
    27 Feb 2004
    hey i'm gonna build a case from lexan/polycarbonate, and I know that it's very shatter resistant, but is 1/8 of an inch thick enough for a case made of this? I'm not making it tower style so it's not going to have to support loads very high up. the 1/8 inch material is MUCH cheaper than the 1/4 inch, i am planning on buying my stuff from this site. thanks :D
    EDIT: Oh i forgot to ask, can you score lexan to cut it or will i have to whip out my hacksaw or jigsaw
  2. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    yes you can score lexan to cut it but it requires strength, and after it breaks alot of filing down to get it smooth. 1/8 lexan is to thin for a computer case, 1/4 is perfect for a computer case.
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I agree. Most aftermarket acrylic cases are 1/4". I used 1/8" for my front panel covers. I did not try but they say lexan is harder to work with than acrylic. Also I tried the score/break deal and was not happy. A hack-saw works great, and you can get very clean cuts.
    http://server6.uploadit.org/files/jeffrey9-IMG_0301.jpg
    MS
  4. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Tutorial I wrote on this subject
    The optimum thickness will depend on the size of enclosure you're trying to build. 1/4" will flex far less than 1/8" and will provide a more rigid structure.
    If you want to get 1/4" at a next-to-nothing price, search your local phone book for plastics shops. Just call a few and ask if they sell any scrap polycarbonate. If they do you can get whatever you need at $2 per pound (sometimes less). The Lexan will be clearly marked (as LEXAN, GE, Rhinex, or Tuffex) and covered in white static film.
    I do not recommend trying to score and snap polycarbonate. To cut polycarbonate I recommend using a variable speed jigsaw with a smooth-cut metal blade. Use medium speed and you shouldn't have any problems with melting. Ideally a table saw is the best tool for the job.
