Displays LG IPS234V or LG IPS235V
Discussion in 'Hardware' started by louist44, 1 Sep 2012.
  1. louist44
    louist44 New Member
    19 Jan 2011
    Narrowed my new monitor choice down to these two.
    Which one would be better? The 235V is only a little bit more expensive but they have identical specifications. (it states on the LG website the size is 21" but it is 23. Which can be seen in some of the specs).
    Thank You
  2. GoodBytes
    20 Jan 2007
    Looks like the same, but different look. I think it's a regional thing.
    The LG IPS234V-PN, will have the plugs come out horizontally on the back. This will be ugly, in the name of mentioning "thin" on the box, and you going: "Oh WOW thin! Imagine all the space I'll save. Oh wait I won't, because the stand takes the same amount of space, and I'll have a tumor on the back of my monitor due to the cables being horizontal. In fact, I might even lose space if my monitor is against the wall. :grr:"
    While the other is the traditional vertical plug layout one.. so the monitor is thicker, to accommodate the plugs.
    louist44 likes this.
  3. louist44
    louist44 New Member
    19 Jan 2011
    Great thanks Goodbytes :)
    I thought there was something more important I was missing!
  4. GoodBytes
    20 Jan 2007
    Well IT COULD, I could not found reviews. But I doubt it.
  5. [-Stash-]
    [-Stash-] New Member
    23 Nov 2005
  6. Jaybles
    Jaybles New Member
    12 Feb 2011
  7. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    ;P just let the guy buy the one for £50 instead of £5 LOL
  8. [-Stash-]
    23 Nov 2005
    I wasn't clear, I was wanting a review of the monitor, not the HDMI cable :D
  9. Jaybles
    Jaybles New Member
    12 Feb 2011
    Ahh makes more sense. :lol:
  10. SuicideNeil
    SuicideNeil New Member
    17 Aug 2009
    Which monitor? I have the IPS234 and it's a beautiful piece of kit ( I have 2 actually, huzzah ). My only slight complaint is the matt film they use on the screen to reduce glare- it has a barely visible diagonal pattern that can be seen when you view the screen from an angle. It is barely noticeable though & you get used to it, otherwise the monitor is brilliant quality and a bargain price.
