Cooling LGA775 coolling/temp poll
Discussion in 'Hardware' started by JavaBoy, 23 Oct 2004.
Thread Status:
Not open for further replies.
  1. JavaBoy
    JavaBoy What's a Dremel?
    21 Oct 2004
    ok i have a few questions
    1st what is the best thermal goup to use
    2nd allot of people talk about breaking it in
    how do i break in thermal compound?
    i need this info asap cause about every 30min my pc overheats and half the time in basicly idle (running mozzila on about 3 website)
    No need for the !!!!!!!!!!!!!!!!!!!! - Haddy
  2. JavaBoy
    21 Oct 2004
    what is up with LGA775 and coolling!!!!!!!!!!!!11
    if you have a LGA775 mobo please list your p4 speed idle time and load temp and coolling stuff that u use
  3. Darv
    Darv Bling!!
    12 Aug 2002
    Did you really need a new thread for this?
    Anyway Arctic Silver is probbably the best thermal paste to use. Breaking it in is just how it settles after the first few days of applying it. Your temps should go down a few degrees after a few days.
    What other cooling do you have in your case? Is the fan actually working on the heatsink? Which heatsink are you using? Have you mounted it correctly?
    What are your temps in the bios? And when you say it is overheating is it actually throttling back?
  4. JavaBoy
    21 Oct 2004
    ok heatsink is the intel 1 that came with the heatsink
    im pretty sure its mounted correctly ive check a couple of times
    i have a abit mobo with uguru and i get reading of about 140 all the way up to 160 idle
    and i mean 160 idle wtf is up with that!!!!!!!!!!!!!!!!!!
    coolling, ok i have 1 120mm fan 1 abit NB fan, heatsink fan, 2 fans on the PSU, and right now i have to side of the case off and a 10inch fan set on high coolling it, but so far that doesnt seem to be doing anything
  5. JavaBoy
    21 Oct 2004
    oh yea i forgot,
    my mobo shuts off my pc @ 167F
    so thats also how i can tell
  6. JavaBoy
    21 Oct 2004
    bump
    how come my psu fans only spin at 600-800RPM's when i boot and login?
    they can go to like 2000rpm's
  7. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    There is no need to keep bumping the thread.
    Plug the heatsink fan directly into the power supply rather than the motherboard. You might need a 3-4 pin adapter to do this.
  8. JavaBoy
    21 Oct 2004
    i dont think the fan is the problem when i put my hand on the sink its not even hot
    right now im thinking its the pice of **** grey pad that came with intel
    btw where can i get a 4 pin psu adaper thing
  9. Darv
    Darv Bling!!
    12 Aug 2002
    Are you using new themral paste. Did you remove the original paste properly.
    Also if the heatsink is not hot it usually means you have it seated incorrectly. take it off and clean both surfaces. Then add new thermal paste and put the heatsink back on. Make sure you follow the instructions for applying paste and attaching the heatsink carefully.
  10. Firehed
    15 Feb 2004
    If the heatsink isn't hot, that suggests even more that it's not seated correctly. I'd check a setting in the bios regarding the fan speed, not worry about an adaptor right now. And a standard 3->4pin adaptor will work.
  11. OneMadPoptart
    OneMadPoptart What's a Dremel?
    14 Oct 2003
    Grey pad? Is this some sort of thermal interface material (like thermal paste in solid form)? ...
    In any case, heat is not being transfered to the heatsink properly. Take off ANY pads, materials, covers, plastics, etc... etc... between the heatsink and the processor, make sure there is nothing between them, put on a nice THIN layer of Artic silver thermal paste and remount.
  12. JavaBoy
    21 Oct 2004
    ya i know i ordered everything (new heatsink thermal goupe)
    i bought the rublin acholul and q-tips
    can you give me tips for cleaning and applying thermal past?
  13. mime genocide
    mime genocide What's a Dremel?
    2 Sep 2004
  14. Lowsidex2
    Lowsidex2 Minimodder
    29 Sep 2003
    I run a LGA 3.4 chip on an ASUS p5a-something mobo and have had nothing but trouble with it. I originally tried to use the stock intel fan but the 'new and improved' mounting really sucks and I could never get a consistant good seat of the fan. When I managed to get to BIOS it idled around 60+ degrees C. I was plagued with shutdowns and reboots until I realized that sucker heated up instantly and needed serious cooling. I couldn't load windows until I got a waterblock for it.
    Anyway with watercooling I get about 30C idle and mid 40's under load. Even when I OC'd it to 4ghz and benchmarked it, the temps never reached 50C. Air cooling is not the way to go with these current LGA chips. Maybe they'll get better.
  15. Haddy
    Haddy World Domination
    22 Jan 2002
    Its just the stock thermal pad that comes on all retail processor's heatsinks...Should work fine for non overclocked systems....Most likely an oc or improper mounting, possibly even a bad sensor but doutfull...
    Questions asked and answered....thread is done...
Thread Status:
