Case Mod - In Progress Lian Li a05 project of fail.
Discussion in 'Project Logs' started by Jeddy, 21 Jul 2009.
  1. Jeddy
    Jeddy What's a Dremel?
    12 May 2008
    It should fit, its deceptive, but there is 17cm of room. My psu is 14cm long
    ty for comments though.
  2. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    it looks damn sexy, and the tiny clearence between PSu and rad makes it!
  3. Jeddy
    12 May 2008
    ty mate. It is an amazing little case, I had one a while back before I got this one. Sold the first one I had to phinix, worst descision I ever made, so I bought this one!
  4. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    yeah mate ur gunna be pushing for space!
  5. Jeddy
    12 May 2008
    Loop is fully tubed and leak tested.
  6. Jeddy
    12 May 2008
    Bit more progress:
    Converted the slim yate to open corners :
    And sleeved another yate and 3pin Y splitter :
    If my heatshrink arrives tomorrow I can sleeve the last yate and a few other bits and bobs.
  7. Jeddy
    12 May 2008
    Another update- luckily post came today, so I got the few bits and bobs I needed :D
    Got the top fan mounted with m3x14mm bolts from modelfixings.
    Feet also came:
    and mounted along with dust filters
    Fans mounted using m4x30mm bolts from modelfixings:
    And now some final progress pics:
    Thats all for now.
  8. H2O
    H2O Burnt Acrylic - Mmmmmm
    1 Aug 2009
    Looking good!
  9. Jeddy
    12 May 2008
    ty H20
    Started on preliminary cable management.
    Cut a hole at the top of the mobo tray (rough I know but wont be seen :p)
    And now I can do this with the top fan's cable (will plug into cpu fan header)
    And started managing the case fan cables (going to be using a molex - 4 3pin cable to power these)
    Trying to go for a really clean cable install. Not easy in a case this small. However as long as it looks good through the window when the lights are on I'm not too bothered.
  10. Jeddy
    12 May 2008
    Got a tiny bit more done on wire management. As far as the yellow heatshrink on the Y adaptor goes, its there for a reason :p. Case fans are on yellow 'shrinked Y adaptor and the rad fans will be on a Red 'shrinked one.
    No no guessing which is which :D
    All the holes and cable ties that looks kinda messy will be hidden by the mobo so no worries there :D
  11. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Looking good dude, I love that case, its not one I would normally associate with water cooling but it just shows where theres a will.................
  12. Jeddy
    12 May 2008
    heh it is probably easier to wc than a PC-7 or similar.
    Sooo much roof and floor space unused :p
  13. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Looks good. Can't wait to see some hardware in it.......
  14. Jeddy
    12 May 2008
    hehe. I am looking at having duniek make me a full cover block for my p5k-premium.
    The ones he has done before for the p5k series are the sex.
    Will be pricy but very worth it for looks.
  15. Jeddy
    12 May 2008
    Baaad things happen when I get bored...
    Firstly replaced horribe crosshead screws on IO panel with nice bolts :D
    THEN I GOT REALLY BORED :p
    Psu in (can you see where this is going ??????)
    DUN
    DUN
    DUN
    So yes the rig is in, and works and the temps are great.
    This install is very basic though, the mobo etc will likely get stripped out again and cables will be properly managed :p
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    nice work so far, check out my Ruby Red build, it uses a A05 too and I shoved two liquid cooling systems in it and well if you have any questions feel free to ask. The link to my RubyRed build is in my sig. Keep up the great work.
  17. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    ...cables!
    Anyway, keep up the good work!
  18. DonT-FeaR
    23 Jul 2008
    holy moly!
    thats a mess!!! still wooooo!
  19. Jeddy
    12 May 2008
    Did some more cable management, looks pretty decent through the window. Not perfect but this case is a ******* to cable manage.
  20. GuyInTulsa
    GuyInTulsa Dremel Molester
    6 Jun 2009
    Nice to see another modder with my level of patients to play with the new toys! :thumb:
