News Lian Li announces PC-V358 cube chassis
Discussion in 'Article Discussion' started by Gareth Halfacree, 17 Oct 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Xploitedtitan
    Xploitedtitan What's a Dremel?
    23 Sep 2009
    OMGAWD, I'm sold...
  3. soopahfly
    soopahfly Minimodder
    12 Jan 2002
    If that's MATX, How small is that bloke?
  4. faugusztin
    11 Aug 2008
    @soopahfly: Pretty much same as every previous PC-V35x series case :
    (W) 324mm
    (H) 286mm
    (D) 390mm
    And too bad they make PC-V35x uglier by every iteration.
    PC-V350 had a nice front : http://www.lian-li.com/en/dt_portfolio/pc-v350/
    PC-V351 added a small vent opening on front, making it a bit uglier : http://www.lian-li.com/en/dt_portfolio/pc-v351/
    PC-V352 removed the signature "line" and instead added a square shaped line and made it even uglier : http://www.lian-li.com/en/dt_portfolio/pc-v352/
    PC-V353 went totally nuts and made the front full mesh : http://www.lian-li.com/en/dt_portfolio/pc-v353/
    PC-V354 doesn't belong to the case line.
    PC-V355 went back to PC-V352 design without the square, and moved the ports on front, which killed the clean front design http://www.lian-li.com/en/dt_portfolio/pc-v355/
    And now in PC-V358 it is even worse : http://www.lian-li.com/en/dt_portfolio/pc-v358/ - they added a big mesh, front mounted slim optical drive without a hiding cover (so if you will mount a dvd drive there, it will stick out visually).
    While internally improved, externally it degraded.
