News Lian Li announces the PC-B12
Discussion in 'Article Discussion' started by brumgrunt, 26 Jul 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. cgp2000
    cgp2000 What's a Dremel?
    10 Jan 2010
    A vent bigger than than the case?
  3. Valinor
    Valinor What's a Dremel?
    30 Oct 2010
    Yep, 1.2m would make for a very large vent. Good cooling though :)
  4. SMIFFYDUDE
    SMIFFYDUDE Supermodders on my D
    22 Apr 2009
    "sniggers" Bottom vent "sniggers"
  5. Gareth Halfacree
    4 Dec 2007
    D'you know, I corrected that - by adding a comma, rather than by removing the extra 0. :duh:
  6. azrael-
    azrael- I'm special...
    18 May 2008
    More images here.
    Although I find the PC-V650 more exciting.
    Not really sure what they mean by "bottom vent", by the way. It's the intake for the PSU and Lian Li has been doing that for some time. Same with the baffle, which usually doesn't amount to much.
  7. Gareth Halfacree
    4 Dec 2007
    No, that's the vent at the back of the base; they're talking about the holes at the front of the base (as seen in the image,) which are in place of the usual holes in the front panel of the case.
  8. azrael-
    18 May 2008
    Oh, I see now. Silly me. Although I first noticed the vent on a large image of the bottom. :)
  9. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    Love Lian Li.
    Pictures do not seem to do justice to their cases.
    In photos a black case just looks like a black case, but in reality that brushed black aluminium is sexy as hell.
  10. docodine
    docodine killed a guy once
    10 Feb 2007
    What's the point of the baffle on the back?
    Also:
    Why write this fluff and not mention what people actually use a 3.5" bay for nowadays, fan controllers, multi-card readers, USB hubs, etc
  11. Guest-16
    Guest-16 Guest
    Ohh I get it, it's a silent case. The fans directed to the floor means less direct sound out the front and the flap at the back has sound matting directly behind it to collect dust kill the noise bouncing off the wall behind. I would guess it's also matted inside the front fascia too.
  12. Gareth Halfacree
    4 Dec 2007
    Because it made me smile - and because I still use an LS120 (well, an LS240.)
Tags: Add Tags
