Actually I've never seen this done before, never seen mesh in the hdd bay, or my little reset mod Hope that I've discovered something that noone has done before Please reply if someone has seen simuliar mods other places, with links maybe?
At last I got my watercooling parts 1 stk. AC vannblokk, CPU, "cuplex PRO" 1 stk. AC vannblokk, GPU (ATI), "twinplex" 1 stk. AC "aquastream" 1 stk. AC radiator, "airplex EVO 240" 1 stk. AC radiatorgrill, for "airplex EVO 240" 1 stk. AC watertank, "aquatube", Silver 1 stk. AC brakett, for "aquatube" 1 stk. AC LED-kit, Blue 2 stk. Papst 120mm fans, 26db 1 stk. Kuriyama, 3/8"ID - 1/2"OD
Also I recieved my new monitor cuple of days ago. It's a Samung Syncmaster 173T But it's got a pixelerror and it has to have more then 3 pixels failed to return it, and I only got one Also
youve got the exact tft/keyboard/mouse/speakers that i was looking and thinking about getting for my new setup sometime this year!! great minds think alike!! i gotta ask though what is the monitor like for day to day use is it just as nice as using a crt or what are your views cheers!
I have a 17" lcd display too, and it has the same fault: one pixel always green! It's a Belinea monitor and, just to answer to planki, I think it's worth the money I've paid. I'm using it for my server, while I'm using a 17" crt monitor for my playing pc; the image quality on the LCD is superb and very bright, while the crt tends to give a more blurred image.. BTW, I use the lcd @ 1280x1024, while the crt is @ 1024x768. Great job on this mod...
Looks like 10mm to me (3/8 inch) To my knowledge that is the largest barb size that is available for Aquacomputer stuff.
How far into the cd drives does that radiator, plus the fans go into the cd drives, I know that the way you have it, its not interfearing with anything, but if it was, how many drives would you have to loose?
That tubing looks way bigger than the stock aqua-computer stuff lol. I loose 2 drive bays with my aqua-tube and rad.
I use Kuriyama, 3/8"ID - 1/2"OD tubes, not aquacomputer, so they're probably a little bit bigger About the floppydrive; I've also tought of your placement, think i'm going to place it there instead. Is it dangerous for the disks if I cut the power to the fans in front? Overheating? They make the loudest sound in my cabinett right now, but I don't know if it's safe.
One thing that always used to irritate me about the large Lian Li cases was the huge amount of unused space, but that accoustic padding really does make it look much better . Seeing that case has made me pine after one . Great job and nice work with the rheobus.
I just have to say: Two thumbs up! I like the look of ur case. its very clean and the noise reduction interior gives it a very nice look. I look forward to some more pictures! Also, if you don't mind me askingm how much did you pay for ur case?
Little more than I'm looking to spend. Guess I'll just stick with my crappy case for now and mod on it
