Can you buy a replacement switch for the 3-speed fan control switch on the front of lian li cases? I want do some modding with that and would like to find a small enough switch that could fit there (and stick thru the front bezel hole) and also be screwed or riveted like the original. Would be a nice place to put a simple on/off switch since I never use their fan controller.
You could easily replace the switch with a simple on off, and bypass their voltage divider circuit... Should be quite simple.
