News Lian Li launches the PC-Q15 mini-ITX case
Discussion in 'Article Discussion' started by brumgrunt, 20 Mar 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Nice, some of Lian Li's other new cases look interesting as well:
    PC-Q25 - mini-ITX NAS case, 8 HD's (inc. 5 hot-swap), standard ATX PSU
    PC-TU200 - mini-ITX LAN case with handle on top and "ruggedised" corners, takes 300mm GPU's
    PC-100 - E-ATX with a rotated m/b
  3. faugusztin
    11 Aug 2008
    Well, my opinion on the new Lian Li cases :
    PC-Q02 - a bit more ventilated PC-Q07. Whatever.
    PC-Q03 - fat brother of PC-Q02. Whatever.
    PC-Q05 - case for one specific board. Whatever.
    PC-Q09FN - a higher version of PC-Q09F with a SFX PSU instead of the TFX or whatever they used in the older version. Good, now you can finally get a silent PSU for this small case, unlike PC-Q09F.
    PC-Q12 - maybe someone will like it, for me it is in whatever category too.
    PC-Q15 - someone at Lian Li got drunk together with his boss. Fan intake - what the hell ? "Wheels" - what the hell ? Remove the divider section at front, make a full hole for the front fan, put the feets on bottom instead of the side - and you got a pretty nice case. But this ?
    PC-Q16 - can't see much, so for now - whatever.
    PC-Q18 - PC-Q08 with better side panels (no million screws as i see), but the hard drive rack is not removable. Why oh why ? 16cm is not enough for Seasonic X and unlike PC-Q08 you can't solve it by removing the HDD rack.
    PC-V700 - looks like ventilated version of PC-A05 with just one 5.25" bay. Nice, if you need such case.
    My suggestion to Lian Li ? Stop using rivets for your hard drive trays, especially in the ITX cases! Use screws, so if someone wants bigger flexibility like me, then he should have the option. For example PC-Q25 is an awesome looking case, but because of the HDD rack, i can't use it. I don't need 5 hard drive bays, i got one SSD like many of those building small ITX systems. And SSD hardly needs more than velcro :).
  4. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    The first thing I thought when I saw that case was: "I could ride that around!"
    Then I discovered that those aren't actually wheels; that gave me a sad face.
  5. Saivert
    Saivert Minimodder
    26 Mar 2005
    At least the case will be stationary like it is supposed to.
    I don't see this as a bad thing.
  6. Alsomething
    Alsomething What's a Dremel?
    22 Apr 2009
    It looks more like a square wagon gone wrong at the front, which is ugly to me.
  7. WILD9
    WILD9 Been here aaaaages
    13 Sep 2001
    I have a small correction :
    "While we can't help but feel a little disappointed that the wheels don't work"
    Should read:
    "While we can't help but feel a little disappointed that the wheels don't work yet"
    This is bit-tech after all, Im sure someone has a spare wheel chair motor lying around! :D
  8. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I can't be the only one who looks at this and automatically thinks of a double-decker bus...
  9. leslie
    leslie Just me!
    19 May 2009
    The wheels don't work?
    Then why bother protruding them into the case taking up room?
    I have been on the hunt for small cases lately, and wow, manufacturers really are missing the ball on this segment. This is just another example, though it is better in some ways.
    And yeah it does look like a double-decker bus, that was my first impression as well.
  10. MajestiX
    MajestiX What's a Dremel?
    14 Apr 2002
    why do itx cases need full size CD ROM and bajillion of HDD
  11. leslie
    leslie Just me!
    19 May 2009
    Exactly what I was thinking with my comment of them missing the ball.
    I don't even use dvd-roms very often anymore, so I use an external USB when I need it. My file server has a single 2TB drive, my dev box has a single 1tb drive, and my desktop has twin SSD's. I don't need 8 internal bays plus 3 externals... My Antec 300 looks absolutely silly with only 2 SSD's in the drive bays.
    I get it that many people do use lots of drives, but they are becoming fewer and fewer and they do need some cases, but there is no reason for every case to cater to that anymore. We have massive drives and many are using SSD's at this point. The average person simply doesn't need tons of bays.
  12. modfx
    modfx Loft Gremlin
    11 Feb 2010
    Single to Brighton please!
Tags: Add Tags
