This is what I wanted - Lian-Li Black ATX Mid Tower Case, Model "PC-V1000B" But, some say they have a problem with the MOBO I wanted MSI K8N Neo Platinum "Make sure you are OK with the front panel connectors though. The front panel audio and Firewire connectors would not reach the headers on my MSI K8N motherboard." Just buy longer connectors or what?
I've found that alot of people (Myself included ) are unable to get the front panel connectors to reach their motherboard. I guess you could buy longer connectors, but doesn't that suck? :\
Depending on the connectors that are inside the case, yes. However my PC60's front USB ports have a strange connector that I've only ever seen in Lian-Lis - so you'd have more trouble finding a longer cable. They might have changed this though, and the front audio cables might also be easier to find a replacement for.
