Lian Li PC-75B case.
Discussion in 'Hardware' started by AH^DK, 3 Mar 2005.
  1. AH^DK
    AH^DK What's a Dremel?
    3 Mar 2005
    Hello.
    I'm a new member in this forum, and I hope that I'm gonna have a good time here.
    Now lets cut the bs :D .
    Lian Li PC-75B, I like this case very much, and wondered if it's a good case? Does it have good mod potential? And what would look good to mod on it?
    Thanks.
    Regards, AH^DK.
    Btw. Mods if it posted wrong, then please move it, thanks.
  2. Wesker
    Wesker What's a Dremel?
    26 Sep 2004
    The PC-75B has a huge amount of modding potential mainly because its so huge. It's definately a perfect case for watercooling. You could always add a psonce lcd in the front for a little flavor :)
  3. AH^DK
    3 Mar 2005
    Okay, I have a Black ICE Pro 120mm, and I have seen some people mounting it over the psu without a hole in the top. Do you know how to do this?
  4. Wesker
    26 Sep 2004
    You have to cut out the top of the psu bracket
  5. AH^DK
    3 Mar 2005
    Okay, but I'll probably get the case home on Monday, and then I will start modding it.
    Btw. the standard 4 ADDA fans, how loud are they? And how many CFM do they pull?
  6. nofear
    nofear What's a Dremel?
    2 Mar 2005
    they seem okay quiet wise (espesially the front ones which you can turn down to almost silent) however i odn't know about the decibels
  7. AH^DK
    3 Mar 2005
    Okay, but can I take the front fans off the controller and set them to my own controller?
  8. Marvt74
    Marvt74 What's a Dremel?
    29 Mar 2004
    Indeed you can,
    You can also put the rad in the front of the case as then you get cold air blown in from the front fans that seems to be a favoured position i think.
    Or at least thats where mine was.
    But yeah potential wise its huge, i remember on another forum one guy was so impressed he was able to fit his head between the cpu heatsink and the psu
  9. AH^DK
    3 Mar 2005
    OMFG! Lol, but I have a frind who thinks that I should buy a Chieftec Matrix instead, should I do this?
  10. Infraggable Krunk
    Infraggable Krunk What's a Dremel?
    7 Mar 2004
    Well I have the little brother pc-65b case and am very happy
    Unless you need that much space I say go with the 65b, but then again I dont know what you plan on doing
  11. AH^DK
    3 Mar 2005
    Well, I'm planing on some day to install a HUGE WC setup in it.
    Btw. if I have a casemod projekt with neon, blow holes etc, then worklogs is the right section right?
    Btw. I'm sorry for my poor english, I'm from Denmark :rolleyes:
  12. Wesker
    26 Sep 2004
    I'd go with the Lian Li over the Chieftec
  13. AH^DK
    3 Mar 2005
    Thanks every one.
    I just ordered a Lian Li PC-75B and a black Vantec Sleeving kit.
