Case Mod - In Progress Lian Li Pc-7HX Grafit !!! COMPLETED !!! IT IS ON !!!
Discussion in 'Project Logs' started by alain-s, 2 Dec 2012.
  1. alain-s
    alain-s Minimodder
    12 Jan 2011
    Time for a small mod named Grafit.
    Last week I have picked up a Lian Li PC-7HX in the local hardware store. I didn't had much choice because it had to be this one.
    With this case I want to enter in the Lian Li Case Mod Competition. I know that the end of the competition is in less then 2 months. ^^
    So lets start!
    Fitting the 420 Rad in the front of the case.
    Removed the alu that is in the way. To make room for the radiator.
    By lowering the radiator in to the hole the top of the case fitted back on it.
    Placed some hardware in the case to check out how much space I have left for all the rest.
    I picked up some new parts from IT-Service this weekend.
    Corsair fans are really well designed.
    Working on this piece of plexi when this is ready I will post a new Update.
    For some reason some of the pictures that needed to be in Landscape are in portrait mode. :s
    Tangster likes this.
  2. Ra6
    Ra6 What's a Dremel?
    4 Nov 2012
    Great! That rad fits perfectly! And nice fans! Are they loud?
  3. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Ra6 well there not louder then my 120mm silverstone fans at 2400 rpm :p
    Update.
    Removed the MBtray and replaced it with a plexi version.
    Used the Original MB tray for all the dimensions.
    Drilled holes taped wire and placed the standoff on it.
    Making the opening for the PCI cards
    Tray in the case
    Using a HDD case from the Cosmos 2
    Saw 3 pieces of alu to make new fronts for the HDD
    First front is ready the rest will follow later this weekend.
    Till next Update. ^^
  4. Ace_finland
    Ace_finland Minimodder
    11 Aug 2012
    Keep up the good work!
  5. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Yess KUTGW :D
  6. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Good luck getting it done in time Alain!
  7. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Good luck mate !
  8. j3akalua
    j3akalua Banned
    9 Dec 2012
    Niceee :)
  9. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thanks Guys will do my best to make the deadline. ^^
    Small Update
    Dismantle my TJ07 this weekend with pain in my hard. I will be needing all the hardware for this build.
    Drainage ^^
    After the draining I cleaned the pc and prep it to put it back in to the box till the buyer comes and pic it up.
    By By :waah:
    Back to the Lian Li case.
    Cutted the top plated in to pieces. And filled up the holes with some 2K filler.
    Reshaping the side panels
    Total picture.
    That was it again I am waiting for some pieces before I can continue with the body and cable management. Hope u all like it so far.
    Cya next time
  10. Ra6
    4 Nov 2012
    That's a nice and interesting cut! ;)
  11. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Nice cut-will there plexi be placed in cut area?
  12. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Ras
    Thanks Prania, the case will stay open but the top will change bit.
  13. Bitwacker
    Bitwacker C# forever
    9 Nov 2009
    Lian Li are always good.
  14. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Bitwacker
    Update!!
    Did a small mod on the heat-sinks of the MB. Because the theme color for this build will be red. I was obligated to change the color of it.
    Removed the heat-sink from theMB
    Filled a small cup with D-stop and placed the pieces that where colored in the cup for 10 minutes.
    Cleaned the product with water. As u can see there are still some blue spots on it. These are the places where the glue was so U wont see a thing of it when the are back in place.
    This way I don't have to sand the pieces and I keep the brushed effect on the parts.
    The HDD case is finished to but I am not convinced by it.
    Had to come up with a new idea for the HDD. Started with some plexi to create a new HDD bay.
    Short movie of how u place the HDD in place
    Case Mod Lian Li PC-7HX Grafit (HDD Cage) - YouTube
    Did the wires already for the HDD and found a spot for the AC poweradjust 2
    That was it again if the mail service do there job good I will have a very nice suprice before Xmess is here.
    Cya next Time. :D
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    I like how this is shaping up. :):dremel:
  16. Editor22
    3 Jan 2009
    Motherboard improvement factor +10 :D
  17. alain-s
    alain-s Minimodder
    12 Jan 2011
    Thank U Waynio :D
    THanks Nate ^^
    Update!!!!
    The update was suppose to be posted before Xmess. But do lak of time with the holidays I only had time to post it today. Time to get a move on.
    Received my 1st package from Nate (Editor22) E22 - Welcome to our website! . Thank U Nate for the great service in this short time. :rock:
    Custom made top res/window.
    And a lovely Cherry MX key chain HL.
    Some extra pins for the powercables.
    Extra colour sample for future mods.
    On Xmess evening I received a lovely gift from my GF. :D
    Installed on the MB
    Removed the top of the case.
    Drilled some holes and taped wire in them to mount the res.
    Didn't had much time these days with all the Family dinners and visits to work on the case. Now that it is all past and over I can continue my work.
    Cya next week for a Update.
  18. Pranja
    Pranja Blackwolf
    18 Dec 2011
    I like this-you have a nice play with curved and straight lines. Nicely done.
  19. sorry2
    sorry2 What's a Dremel?
    1 Mar 2012
    Alain shifting in win mode :thumb:
  20. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Bloody hell that looks awesome!!
    I'm definately following this one
