Case Mod - In Progress Lian-Li PC-A05 Quick Mod - Assembled case PICS
Discussion in 'Project Logs' started by Pashtet, 27 Sep 2009.
  1. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Hello again!
    While Project "CUBE" is waiting for the powdercoating, I have some free time to look at my friends' LIAN LI.
    So here starts a very quick and basic mod for the PC-A05.
    The main goal is to achieve maximum cooling in this tiny case. The PSU location and lack of ventilation holes make the front panel become very hot after a very short time of gaming. There is a solution and I'm going to use it.
    Let's start with the case itself. Nothing special, a very common black version of PC-A05. Here's the unboxing process:
    There is a good solution for the better cooling of the case and all the hardware (if only we do not watercool it) - making blowholes on the top panel of the case for the hot air to be blown out by the fans. So starting with the marking the future cuts. First applying the layer of masking tape.
    Then drawing the hole to be cut.
    Here I'm going to use my own lasercut Fan/Rad grill. It has standard spacing between fans' mounting holes (15 mm) and can be used in future (watercooling, for example).
    It's made from 3mm thick black glossy acrylic. Very shiny :D
    Another hole is going to be placed in the lower part of the front panel - it's for the PSU to blow hot air outside of the case.
    I'm going to cover it with the "modders mesh". But there is no "modders mesh" here, in Odessa. But there is a lot of TRUE Recycle Bins sold everywhere. And they have an amusing price - around 5$. And it's great!
    And what a casemod is it without window on the side panel? :duh:
    Masking and marking the sidepanel window
    Everything is ready, let's begin cutting and drilling!
    :dremel::dremel::dremel::dremel::dremel::dremel:
    4 hours later...
    Damn! My jigsaw crashed and I had to cut everything with my dremel :wallbash: And you know how it is, to cut thick aluminum with dremel :)
    After the initial cuts we have this:
    I decided ti leave the LIAN LI logo on the front panel just because I like it very much :blush:
    Tomorrow I'm going to file and sand all the cuts, place the mesh and acrylic, and it's done! Not the biggest mod, but this is going to be an elegant case without "Christmas-tree-lights" and other ugly things :)
    Jack_Pepsi likes this.
  2. stuartwood89
    20 Aug 2008
    Looking very nice so far. Looking forward to the update!
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    +1
  4. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    stuartwood89, perplekks45
    Thanks guys! Update is coming :)
  5. wbdog206
    wbdog206 not me
    15 Jan 2007
  6. stonedsurd
    11 Mar 2009
    I truly, truly feel for you.
    Great project. Looking forward to more updates.
  7. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    wbdog206
    Thank you!
    I really appreciate your feedback, guys!
    stonedsurd
    It wasn't very easy, but I managed to do that :)
  8. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    1st of 2 updates :)
    Today I had lots of things to do except modding :( But I found some 2 hours to sand the panels of the case.
    First the front panel. Here is the pre-finished result of its ventilation hole
    Then moving onto the top panel with its fan grill. As Imentioned earler the grill is very glossy and shiny! ^__^
    (Damn that dust! I swear, final pics will be dust-free!)
    I had to make a decision which bolts should I use - philips or allen? Thought that allen headed bolts will look better :)
    Offtop
    I've got a "virgin" screw nut :D:D:D
    /Offtop
    Then moving onto the side panel. It isn't finished yet, but it has only to be sanded fo a couple of minutes, mainly the corners of the window.
    And now, for the end of this update - one more "eye candy" photo of the case in 3/4:
  9. Pazu
    Pazu What's a Dremel?
    10 Aug 2005
    Beautiful laser cut grill, dude. :)
    Must be a day of the A-05, mine was posted slightly after yours.
    Will be tracking this build, so hard to find mods of the A-05!
  10. stuartwood89
    20 Aug 2008
    I would always go for allen screws over phillips in a PC build, the just look so much cleaner.
  11. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Pazu
    I saw 3 new project logs for the A05 yesterday :) This really could be the "Day of PC-A05"
    stuartwood89
    sphere headed allen bolts are the most beautiful, but I can't find where to buy them :(
  12. The boy 4rm oz
    10 Apr 2008
    I like what you have done to the front.
    LOL@ the virgin nut hahaha.
  13. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    The boy 4rm oz
    TY
    I like the front most of all :-[
  14. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
  15. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    ??? lol
    love the custom fangrill. your cuts are very clean
    id have to agree with stuart. allen key bolts. no question. (unless torx or tamperproof torx)
  16. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Update #1 1/2 :D
    Being a PhD student is very painful :D And it doesn't leave any time to modding :(
    Today I only managed to cut and form the front panel mesh. I'm going to glue it to the panel with epoxy adhesive. So the front panel will look like this -
    Hopefully tomorrow I'll finish with the front and pay attention to the side panel.
    BTW, guys, what can I use to attach clear acrylic to the side panel? Some double-sided tape or epoxy, maybe there's something else?
  17. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Oreon_237
    Thanks!
    The grill is lasercut, so the edges are very clean and straight
  18. stonedsurd
    11 Mar 2009
    Is it just me or does the mesh bulge out a little? nice touch.
    Also, for the window, both tape and epoxy will do fine but I prefer tape because it's a little less permanent.
  19. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    stonedsurd
    yes, the mesh is bent to be in one level with the panel
  20. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    Update #2. Front Mesh and Side Window
    Okay, it's the last update before the final pics!
    Attached previously bent mesh to the front panel using 2 monstrous drops of epoxy glue :D
    Then used "super-duper-strong" double-sided tape made in china to hold the clear acrylic of the side panel
    After that - it's time for the final assembly pf the case. Removing all the glue left after the masking tape, cleaning of the dust and aluminum pieces after filing and sanding. And here we go -
    FINAL PICS (in the next post)
