Case Mod - In Progress Lian Li PC-A70F - black and white
Discussion in 'Project Logs' started by flix, 25 Nov 2011.
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    This mod looks very promising my friend! Mod on! :)
  2. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Simply amazing
  3. flix
    flix Minimodder
    5 Aug 2009
    Thank you :D
    I have a small update for you.
    I've agglutinated the three plates. It doesn look perfect but for me its more than enough because there will be an aluminium sheet mounted on it. However I have to grind and polish it.
    On top I made a scre thread. I'm so happy that it works, one fail and the whole work was for nothing. But it works :D
    Here you can see some air pockets, next time I have to use more glue to avoid that.
    Thanks for reading :)
  4. flix
    flix Minimodder
    5 Aug 2009
    I have a "small" update for you ;)
    I bought a hole saw, very usefull tool.
    works great:
    Filed down the metal sheet.
    After that, I continued with the inside fan grill for the upper side of the case.
    At first marking -> center punshing -> drilling
    At first with a 3,5mm drill and final with a 10mm one
    After I've drilled all holes I have to connect them. I took my jigsaw an began to cut.
    filed and grinded
    The metall sheet for the front inside must be bended, so this was my bending mashine ^^ :
    This was the result:
    I think: big fail :D
    Next try becomes much better. I milled a dent into the sheet. I used a Dremel and file.
    I was very happy with the result so I want to make the final sheet. The bending looks nice but the holes I drilled before were at a wrong positions.
    Next try:
    Finished that and make a side panel for that.
    assambled everything again:
    Hope you like it :dremel:
  5. Razarach
    Razarach Minimodder
    28 Jan 2009
    Very nice my friend :dremel:
  6. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Wow, this case is really nice!
  7. dreps
    dreps Minimodder
    3 Oct 2012
    looks very nice aready :D can't wait to see the finished result
  8. whyte
    27 Mar 2012
    absolutely amazing. your skill w with a jig saw is impressive.
  9. flix
    flix Minimodder
    5 Aug 2009
    Thank you guys :)
    After a long break I will go one with this project :)
    In the last months I work on a Lian Li Casemod for a Contest. For anybody who is interested, pictures can be seen on my Facebook page.(page is still in german, I'm thinking about switching to english if somebody is interessted)
  10. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Looks great but to avoid the air poccets in the plexiglass use plexiglas cement.
  11. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Wahnsinn, ich wünschte ich könnte auch nur ansatzweise so gut mit Metall umgehen. Super Projekt bisher!
  12. Saltire35
    Saltire35 Drunken Scotsman
    5 Dec 2010
    Any plans on powder coating the interior ?
    Excellent build btw. [​IMG] from me.
    *Edit* Apologies, just read your initial post... can't wait to see the powder coating done.
  13. flix
    flix Minimodder
    5 Aug 2009
    Thank you guys :)
    @saltire35: I actually dont know If I will powder coating this case. There are some reasons that prevents my doing that. I can do it on my one. I filled some parts with normal filler. I already have some cans of varnish here.
    But I know... powder coating would by nicer... I'm still undetermined.
  14. flix
    flix Minimodder
    5 Aug 2009
    Small Update for you :D
    Maybe you allready have noticed that I aspire a clean look. So I want to hide all cables.
    I decided to make a 90° connector.
    This is how I have done this:
    original state:
    drilled some wholes and cut down the overlaying pieces:
    organised some flat cables, cut and crimped them:
    The first cables in the connector:
    Cut out this piece of aluminium:
    and glued it on the connector by using 2K glue. need to file it down a little bit.
    The cables should disappear behind the aluminium plate:
    Besides that I bought some self made circuit boards, I will use it to make the connectors for the GPUs. :)
    At first I cutted a small sheet to have the PCB. Cutting this smells like hell :miffed:
    I have to the crimps and soldered in some whires:
    And nearly finished, just the cables are missing:
    Gpu connector finished on the side of the gpu. My soldering skill aren't very good, but I will make a cover for it.
    Thats it for now ;)
  15. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    I really like what you're doing with the cables, I think it's an awesome idea! Really looking forward to seeing how this shapes up! Keep up the good work.
  16. flix
    flix Minimodder
    5 Aug 2009
    Thank you :)
    Lately I dont have the time to work a lot on this project, but I've done some small mods to on the hardware.
    I've opened the Laing D5 to change the cables:
    Besides that I decided to change some parts on the mainboard, it was too colorful... :)
    ... and I cleaned the caps and removed some decals:
    Some more pictues:
  17. dreps
    dreps Minimodder
    3 Oct 2012
    sir you got skills!! I would have never messed with the Mobo connectors :p
  18. maRiio
    maRiio What's a Dremel?
    27 Jul 2009
    That's some nice MoBo-modding there ;) I especially love the connections for both of the graphics cards :thumb:
  19. flix
    flix Minimodder
    5 Aug 2009
    Yes its true, it goes on :D
    The power Connector for the VGAs and Mobo seems to work, but the hardware in general seem to have some problems... even with some original cables...
    At the moment I think I will change the whole hardware... at first this was just a fun project, but now I think I will use this system as my main system.
    The problem is, that the tubing routes are defined by the acryl plate with the pumps. I need a mainboard which has an PCI-E Slot at the second and sixth position on a normal ATX Mainboard. I couldnt find a fitting board with a Z77 or Z87 chipset. Hmm... If I want to change, I need to upgrade on a X79 System.
    Thinking about this problem I want to do some metal work.
    I cutted and bended an aluminium sheet for the front.
    This is the current status:
  20. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    That's certainly a nice front panel. Planning to polish it/brush it/bead blast it?
